Question about Gigabyte Computers & Internet
I need front panel connection pin diagram for GA-8SIMLNF NEC Commputer
kigwa2008
  • 68 Answers
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Posted on Jul 25, 2008
  • 56 Answers
SOURCE: Would like to find the pin sequence for the
black green white red inside row nearest battery,starting from the front facing end.
Posted on Aug 13, 2010
map9966
  • 2351 Answers
SOURCE: No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Posted on Mar 14, 2008
SOURCE: need motherboard manual for a gigabyt GA-8SIMLNF
I set up this same mobo after my old one died and this was all I had. The manuals are fine except they have more pins than my mobo. Mine only has 9 pins, 4 at the top and 5 on the bottom. I got it to power on with the POWER SW on the top right hand 2 pins, positive to LHS I think. It doesn't matter if they're around the opposite way as it won't damage the board. The bottom left hand 2 pins are your HDD LED and the next 2 pins are your RESET SW. These pins are positive to RHS. The bottom 5th pin on the far right is not used. I tried all combinations on the 2 top left hand pins for the PWR LED but got no result so just left them off. I tried a P4 3GHz but it would only turn on for about 5 seconds then shut off. Maybe the BIOS is set only to accept a Celeron CPU. A BIOS upgrade may be in order.
Posted on Jul 28, 2009
My GA 8SIMLNF motherboard keeps shutting down the PS. I'm convinced heat is NOT the issue. I tried a new good PS from my other PC and exactly the same problem, so it's not voltages either. I'm convinced...
This definately sounds like a bad motherboard. I had a bad psu that was shutting down my system one time. I took it back and got a refund and got another one. Installed and never had the problem again. you said you already checked the psu so yeah thats what it sounds like.
Mar 15, 2011 | Computers & Internet
In Device Manager the Multimedia Audio Controller is marked with a yellow question mark The Belarc report says System Serial Number: 035289220160 Chassis Serial Number: 50424E Enclosure Type: Desktop...
I have the same problem and its all ready got the driver there and when i go in to system managment and reinstall multimedia audion controller it shuts down i installed driver finders which were suggested in a few forums and they find every other driver apart from the one thats messed up help ????
Dec 25, 2010 | Computers & Internet
What is the correct connections for Packard Bell GA-8SIMLNF motherboard Front Pannel.As I can't read the markings on the board
Hi willow422,
I understand that you need the pin configuration for your front panel. This link will help guide you setup your front panel.
Link:
http://support.packardbell.com/uk/item/index.php?i=spec_columbia6&ppn=P862000601
Jun 16, 2009 | HP Computers & Internet
How to connect plugs of front panel in the main board?
the power switch connector goes vertically where it says pw on the pins at the bottom right of the board. there is a diagram in the user manual on page 23. you can download the manual fro their website.
Thanks
Apr 05, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Mar 13, 2009 | Gigabyte GA-8SIML Motherboard
Which pins from the front panel of 6WMM7 go where?
There should be printer words on the motherboard next to the header. Use a magnify glass to look in and see. I will look for a diagram for you.
Mar 08, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Ga 8simlnf ram upgrade
There is no motherboard with this model number. Can you recheck this by looking on the board itself. Its right in the middle of the board.
In general though, you can usually put 4GBs of Ram in the G8 series but only Vista and later Linux versions will actually report above 3GBs.
Please reply using the comment box below. Thanks.
Regards,
Worldvet
Aug 17, 2008 | Intel Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Open Questions:
Computers & Internet Logo
392 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
