Question about Motorola Mobility H700 Wireless Headset
Motorola H700 My HP Pavilion is not finding this device, can I listen to music with the HP like I can on my other CPU?
    Scholar:
  • 125 Answers
Is your HP Blue Tooth compatible? Check the specs for your system and see. If it does not say it has Blue Tooth compatibility then you can buy a rather inexpensive Blue Tooth doggle that plugs into one of your USB ports.
Posted on Jul 11, 2008
How do i put the motorola h700 in pairing mode
Hi terantra,
I would like to assist you with your Motorola H700 headset, Please see steps below.
  • Make sure that there are no other Bluetooth devices in the area.
  • Now set the device that you want your Motorola H700 to pair with make sure that it is detecting devices.
  • Now on your H700 Motorola press and Hold down the Multifunction Button on it, and open the mouth piece.
  • This should be detected right away by the device that you are pairing the with the H700, the pairing Code for this H700 will "0000"
I hope that his will be of help regarding your concern.
Have a nice day,
mvincent
Apr 22, 2011 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
My motorola h700 won't turn purple to connect to my motorola i576
Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
Dec 20, 2009 | Motorola Mobility H700 Wireless Headset
H700/ blackberry storm
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 11, 2009 | Motorola Mobility H700 Wireless Headset
How do i record internet radios and translate it formats?
easy!
I found an efficient radio recorder with good quality,you can use it to free listen radios,record and convert radio music to all popular formats,so you can listen the music on your pc or other mobile devices.
May 25, 2009 | HP Pavilion dv6000z Notebook
Having problems pairing motorola h700 with blackberry curve
Mar 23, 2009 | Motorola Mobility H700 Wireless Headset
H700 won't play music thru bluetooth
Pushing in the button (I don't know what you mean by "the middle button" when there is only one button on the H700) it starts the voice dial feature. It will listen for a second and then tell you with a beep that it did not recognize the name. That is your cue to try again. When it does not recognize it again in a couple of seconds ti shut off. The H700 was not designed to use to listen to music on your phone with. If you want to do that you need to purchase something like the Motorokr Blue Tooth unit.
May 19, 2008 | Motorola Mobility H700 Wireless Headset
Motorola hS 850 wireless headset
How Can You Listen To Music On The H700?
May 13, 2008 | Motorola Mobility H700 Wireless Headset
Listen to music
You defently can. I do with my moto q and my h700
Feb 12, 2008 | Motorola Mobility H700 Wireless Headset
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
