Question about Acer Computers & Internet
Hello, my acer Aspire 5100 doesnot support dvd rw after format. hw to install dvd drive
The best thing is to buy a new laptop....
Posted on Jan 06, 2011
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
I want to replace the dvd drive for acer aspire 5100-3357 with another internal dvd drive but I do't know the type or the model #, all I know is that is a super multi double layer and supports DVD +-...
A better not complicated solution is an external drive.
Like the:
LG GP08LU10 Optical MediaSlim External Super-Multi DVD Drive You might not know it from looking at this DVD drive's sleek, slim exterior, but it's loaded with capabilities. LG's external CD- and DVD-burner looks great, and works in four unique formats. Super-multi read-and-write lets you select your style for maximum performance, while the USB connection means there's no need for an AC adapter.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Acer Aspire 5100-3357 Notebook
Hi, my DVD-RW keeps disappearing from "my
Hi, There is nothing wrong with your CD/DVD drive.
Your Registry is corrupt. Now you are missing the Upper or Lower filters(or both) on your CD/DVD drive.
Try System Restore and here's a Microsoft article on the subject.http://support.microsoft.com/kb/314060
regards, sathyamoorthy
Nov 14, 2010 | Acer Aspire 5100 Notebook
Just installed a new hdd 500gb on my acer 5100 and now it won't read the recovery disc. Plz help. Dwayne
is the hd formatted?
when the computer is booting, hit the f12 key. this gets you to the bootup sequence windows. highlight the cd/dvd drive as first startup. reboot w/the recovery disk in the drive. this should allow you to format the hd and then install th files on the recovery disk.
Dec 24, 2009 | Acer Aspire 5100-5022 Notebook
DVD/RW not recognised by laptop
download everest it's driver software that finds the drivers that are best suited for your computer it has a free 30-day trial (you shouldn't need it for longer) that will for full all your driver needs!
Download Now
Jul 15, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 8X DVD±RW DL Burner Drive UJ-850 dvd burn only small files, don't burn movies completly. Itried with several programs like nero , image burn,gburn, etc....sometimes works well, the...
Instead of trying to remove the internal drive, which is still useful, do what I did and buy an external DVD drive, just plug it in with a USB cable...then you still have your internal for nornal stuff and you can move the external around anywhere to take care of the heavy duty stuff...good luck..pls rate this solution.
Apr 23, 2009 | Acer Computers & Internet
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
My computer says i dont have a dvd-rom but its there
hello i a have couple of questions is the dvd the one that came with the computer or did u buy it somewhere 1 if it the one that came with the acer then try here to get the drivers http://driver-pro.com/related/english/hardware-drivers/?gclid=COiGzNu-vZkCFQVhnAod41hc7w&hit=1&adurl=12034
when u get to the site scroll down slect from the list ur operating sys slect dvd and so on that should fix the problem
hope this helps you
bob
Mar 25, 2009 | Acer Aspire 3100-1405 Notebook
PIONEER DVD-RW DVR-K17RS ATA DEVICE VISTA HOME EDITION MISSING
This tends to happen to some drives...do you leave a disc in the drive when shutting down the computer?
you will have to restart it and take out the disk, or click on the "removable drives" tab in "My Computer" and hit the right arrow
Feb 12, 2009 | Acer Aspire 5100 Notebook
Acer 5100
please to go to your bios setting and check under boot sequence whether your hard drive is the 1st device. try to reset the bios to its default settings and after resetting it try to check again on the boot sequence to make sure that your hard drive is the first option. if you have external devices connected to the computer remove all of it.
Jun 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
