Question about Fujitsu ScanSnap Manager
My ScanSnap Manager will not load at all. It would normally open on startup but in addition to not starting up I cannot open manager manually from the start menu?
5 Suggested Answers
SOURCE: driver scansnap
What needs to be deleted in the registry?
Posted on Sep 12, 2008
SOURCE: Won't install ScanSnap Manager
The CD is defective. Get another CD and try it. I was having the same problem. I browsed the CD because I wanted to install just the Scan Snap manger. I discovered that the CD ROM could not read that part of the disk, so I tried the installation from another CD disk, and it worked like a charm.
Posted on Oct 23, 2008
SOURCE: error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Posted on Jan 12, 2009
SOURCE: application button (tab) missing in
Right-click on the ScanSnap system tray icon and de-select the 'Use Quick Menu' option. When you reopen the ScanSnap manager, you should now see the application tab.
Posted on Mar 15, 2009
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
ScanSnap Manager - Error!! You do not have a write authority for the installation folder.\nMake the selected folder writable.
Normally this error will only come up when you have already tried installing the Scansnap Manager.
Go to C:\Windows\SSDriver. Right click the folder and select properties, select the security tab, then make sure "Users" has full control.
Repeat these steps on the PFU folder in Program Files.
Put in the Scansnap disk and navigate to the Tools folder. Run the SSCleaner tool and delete all of the Scansnap components.
If Scansnap Manager is not listed in the Cleaner tool, Delete the contents of the SSDriver and PFU folders manually.
Restart the computer and reinstall the components.
May 14, 2009 | Fujitsu ScanSnap Manager
Scansnap manager won't properly install on windows xp...
Problem solved. Ignore the "Windows XP approval" message & continue with the fix suggested in the troubleshooting section of the manual.
Feb 18, 2009 | Fujitsu ScanSnap S510
Application button (tab) missing in scansnap manager
Jan 12, 2009 | Fujitsu ScanSnap Manager
Error while attempting to install ScanSnap Manager on Win XP Pro
Jan 09, 2009 | Fujitsu ScanSnap Manager
Scansnap 510 on Vista 64 bit system?
Yes, it *IS* possible to run your ScanSnap S510 scanner on a 64-bit Windows operating system (e.g., Vista 64-bit, Server 2008 64-bit, etc.) but you will need to contact Fujitsu customer support (go to Fijutsu's website and look up their telephone number) and ask them to send you the link (along with username/password) to download the 64-bit versions of the ScanSnap Manager software as well as the CardMinder & Organizer software (optional).
FYI, as of March 2009 that is, the 64-bit version of the ScanSnap Manager is 4.2 L14 and the actual file name that you'll be downloading from Fujitsu's website is called "ssWv42x64.exe" (220 MB file).
Again, this software is NOT available from the public portion of Fujitsu's support website due to legal licensing restrictions. Additionally, this is NOT the same thing as some of the "updates" for Vista they have floating around the public technical support portion of their website.
Hope that helps!
Dec 31, 2008 | Fujitsu ScanSnap Manager
Driver scansnap
There should not be any problem installing that sofware on that OS and version. My guess is you have a botched (corrupted) install. Try uninstalling if you can otherwise let me know and we'll "clean out the registry." Good luck!
Jul 22, 2008 | Fujitsu ScanSnap Manager
Computers & Internet Logo
2,443 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
