Question about Microsoft Internet Explorer 8
Certificate Errors in Internet Explorer 8 - Microsoft Internet Explorer 8
    President:
  • 2,291 Answers
Update ur ie , try to reinstall it clear all history and clean registry keys with reginout
Posted on Oct 15, 2010
Is windows internet explorer 8 the same as microsoft internet explorer 8
Restoring Computer to earlier state is the best solution. Only update the Internet explorer by using online updates that is downloaded from Microsoft website. WebRepOverall ratingThis site has no rating(not enough votes)
Also try to update the drivers that control your PC.
If problem still occurs then use system utility tool PCFresher that will fix windows internal errors and will fix corrupt registry errors.
Dec 07, 2012 | Microsoft Windows XP Professional for PC
Tip
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
on Mar 29, 2010 | Computers & Internet
How do I fix internet explorer security certificate errors
You can't fix the errors, the problem is not on your end.
Jan 16, 2012 | Computers & Internet
Internet explorer blocked website from displaying content with securiy cartificate errors
it means internet explorer does not trust the website because the security certificate is not recognized by IE. you can right click the content blocked and click the allow option on the drop down menu.
Sep 29, 2011 | Facebook Computers & Internet
Some pages on Internet Explorer 8 do not open Message: Done but with Errors
This message means that the code used on that web pages has errors on it (not in accordance with W3C rules). The error is not on your machine.
Mar 22, 2010 | Microsoft Internet Explorer 8
Since yesterday, when the computer was accidentally unplugged, I cannot get onto any website; Error message: Certificate Error: Navigation blocked. I'm using Windows XP 2000, Internet Explorer 8. I can't...
IF you are on DSL, try reseting the modem by powering it down. Sometimes you lose the address and reseting the modem forces it to cough up a new one.
Nov 10, 2009 | Microsoft Internet Explorer 8
Ask for certificate while opening gmail.com certificate errot Navigation blocked
fix time and date ...it might not be ok ..and it sees that the certificate you are running it not in use until some time after ...and this might cause it ...if it is not this ...uninstall the explorer 7 ...it will roll back automatically on explorer 6 ...and all will be ok ...
so go to ..c panel ...add/remove programs....click on explorer and click remove ...follow the instructions...if you really want it ...you can reinstall it from the net ...and any errors will be gone..
Nov 04, 2009 | Microsoft Internet Explorer 7
When i go to yahoo email i get told the security certificate has expired or i dont have one also my date and time is at january 2002 can you help thanks
Most security certificate are valid for a year or two. If you computer's data is out of that range it will assume the certificate has expired or hasn't yet become valid.
The first thing to do whenever you have certificate errors especially on secure websites is to check the clock.
Right click the clock and click adjust time/date and make sure the Time.....the Day....the Month and the Year are all correct....and finally check you are in the right time Zone.
While in Internet Explorer, click "Tools" > Internet Options > Advanced. Scroll down to the "Security" section and uncheck the "Check for publisher's certificate revocation" box.
Oct 18, 2009 | Yahoo Mail
Internet explorer 8 version 20090308 will not
here is my advice : Just go to www.microsoft.com and download internet explorer again and install it , then reboot your system . I'm sure that this will solve the problem . any way , why don't you try other internet communication softwares like ( firefox or google chrome) those both are great also . I advice you to have more than one internet communication software . I already have three just in case if one of them is corrupted . I have ( Internet explorer and firefox and google chrome ) . just try the idea and you'll be satisfied with the result .
If that didn't help then try to check system for errors . such as registry errors .
good luck .
rate if useful please !
Sep 23, 2009 | Microsoft Internet Explorer 8
Internet Explorer Certificate errors
Make sure the date and time on your computer is correct. You can try changing the setting in your internet explorer but I would personally recommend a completely different browser. My personal favorite is Mozilla firefox.
http://www.mozilla.com/en-US/
You could also reset the internet explorer back to defaults.
Aug 02, 2008 | EliteGroup ECS P4M800-M Socket...
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
