Question about Quantum Fireball (LM20A011) 20.5 GB Hard Drive
SMART Failure Predicted on Primary Master QUANTUM FIREBALLP AS20.5 Arturo Sghedoni
  • 32,281 Answers
This error message is a warning that the hard drive may fail in the near future. It is advisable to backup your data frequently so that when the hard drives fails you will not lose your data.
Posted on Oct 14, 2010
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
Smart failure predicted hard disk2:wds 1600bevs _ 08rst3_si
Smart gives indication of failure but can't give you a time frame, I would suggest backing up critical files as soon as possible since it could go at anytime.
May 15, 2012 | Lenovo 3000 N200 PC Notebook
Smart Failure Predicted on Hard Disk 4
Are you sure you don't have a usb or other device plugged into your computer. Your main hard drive should be disc 0. Disc 4 is usually a disc further down the line, like an external or something like that. If it indeed the case then you may be having a problem with the boot in your primary drive. Try booting the disc with a windows installation disc. load the dosc and boot, when it says so, hit any key to boot off cd. When windows loads, hit repair this installation. It will reboot when it is ready. If that doesn't take care of it, reload the disc again and try to restore the drive to an earlier time, like a day or two ago. If this doesn't work, you may have to get another hard drive and reload the system. Don't get rod of the other hard drive though because you may still be able to access the personal files off of it as long as it hasn't had a mechanical or electrical problem keeping it from spinning.
Sep 13, 2009 | Dell Inspiron 1501 Notebook
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Acer 1642 laptop is giving me much trouble. Was working fine until, fapoot... now i receive a message: SMART failure predicted on hard drive 0:ST6100825A-(PM), please help if you can
A SMART failure means that your hard drive is predicted to fail
soon. Fortunately these warnings are not right 40%-50% of the time. Go to the command prompt (start- run- type in "cmd")
In the prompt type in "chkdsk"
This will run tests on your hard drive and tell if there is anything wrong with it.
Dec 28, 2008 | Acer Aspire 3610 Notebook
"primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
American Megatrends is telling us our Pri Master Hard disk: S.M.A.R.T. is bad, backup and replace.
By questions and answers from above, is this telling us to replace hard drive?
Aug 14, 2008 | Samsung (SP0411N) 40 GB Hard Drive
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Quantum Fireball (LM20A011) 20.5 GB Hard Drive Logo
199 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
