Question about Cameras
Lens error lens is jammed i let camera fall could You please give me a contact so that i can use from Northern Ireland
  • Cameras Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 14, 2010
Camera will not "close"
Feb 17, 2011 | Canon PowerShot SD960 IS Digital Camera
When i turn on my canon powershot s3 iS , it says lens error restart camera. i tried restarting it , but my when my lens are trying to come out it makes a jammed noise. CAN YOU PLEASE HELP ?!
Feb 13, 2011 | Canon PowerShot S3 IS Digital Camera
Jammed lens
Oct 31, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
The camera falls down then when im about to boot it up the camera lens didnt extends and then shutting down and said "lens error"
the camera must have fallen on the lens jamming the motor that drives the lens, you will need to visit the local service center to get the problem sorted out
Apr 11, 2010 | Casio Exilim EXZ75 Digital Camera
Error code 99. Please tellme what this means.
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 03, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon camera err 99
Error 99 is when the lens contacts aren't making good contact with the matching gold contacts on the lens opening of the camera body.
An easy remedy is to take a clean pencil eraser and lightly clean the contacts on the lens and the camera body. Be sure to not let any eraser crumbs fall into the camera body....
Reinstall the lens and see if your error is cleared.
K
Sep 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
I have a canon eos digital camera. It has error 99 code on it when I try to take a picture
Error 99 can be caused by poor communication between the camera and the lens. Often it can be resolved by doing one of these following fixes:
1) Turn the camera off, remove the lens, replace the lens, turn the camera on.
2) If that doesn't work, turn the camera off and remove the lens. Use a clean pencil eraser to clean the electrical contacts between the lens and the camera body. Hold the lens or camera body "upside down" so that the contacts are facing down as you rub them with the eraser so that any eraser debris falls onto the table rather than falling into your camera or lens. Replace the lens.
If neither of these fix your problem you will need to send the camera and lens in to Canon for repair.
Dec 25, 2008 | Canon EOS 40D Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Error 99 can't make a shot
Oct 26, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
29 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
