Question about Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera
Sd card is locked on my DMc-ZX1 digital camera :-(
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Oct 14, 2010
2 Suggested Answers
  • 152 Answers
SOURCE: Lumix DMC-ZR1 / DMC-ZX1 Digital Camera: My lumix dmc-zx1 got wet with normal sweet water t...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to take out all moisture trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
Posted on May 24, 2010
I tried to edit an image on sd card in Panasonic DMC-ZX1 via PC. Now camera will not recognise any card and will record only to internal memory. Card works in PC. What are my options?
First, back up any important stuff to the PC. Then format the card in the camera.
In the future, avoid doing stuff on the card. Copy the image to the PC, edit it there, then copy it back to the card. Be aware that any edited photos may not be visible on the camera.
Nov 21, 2016 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I have pictures in the memory of the camera (not on the sd card) and I can't get the pictures to transfer to the computer. I can't find the file for it. Help!!
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 02, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Need driver PC lumix dmc zx1
Having gone over a month without a resposen to my query, I assume my suggestion to use a card reader eliminated the need for a camera driver.
Jun 17, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
My camera says the memory card is locked so i am unable to delete pics or do anything
Step 1 : remove your card from the camra
Step 2 : on the edge of ur card u wull have a kind of switch. you just have to move it in teh opposite direction. if it is up pull it down and viceversa
Step 3 : put ur card back in camera and u can delet all teh pictures that u want to delet ;-)
Enjoy deleting.
Apr 28, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I have panasonic lumix DMC ZX1. when trying to take pictures it says pictures will be stored in inbuilt memory inspite sd card being inserted in right place and empty.
Welcome to FixYa.
Before using the memory card, it should be fromatted. Possible reason is memory card is not yet formatted for camera use.
*Note: Use the camera itself when formatiing the camera. Using PC's or another camera in formatting the memory card may cause a "CARD ERROR" message.
If the switch on the card is set to "LOCK"; operations such as formatting, recording and deleting cannot be performed.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 12, 2011 | Panasonic DMC-ZS1 Digital Camera
How to unlock the memory card
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 11, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Shows: MEMORY LOCKED
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 23, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I just bought the Lumix DMC-ZR1 (yesterday April 3rd) When I put the memory card in, and it's blank, the camera reads that the memory card is full....how can I fix it??
In the instruction manual - see links below
  • It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit You can use an SD Memory Card and SDHC Memory Card. •When the term card is used in these operating instructions this refers to the following types of Memory Cards. – SD Memory Card (8 MB to 2 GB) – SDHC Memory Card (4 GB to 32 GB) More specific information about memory cards that can be used with this unit. • You can only use an SDHC Memory Card if using cards with 4 GB or more capacity. • A 4 GB (or more) Memory Card without an SDHC logo is not based on the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 04, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera Logo
71 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
