Question about Hoover Washing Machines
I bought a hoover washing machine. model number hse-140. the machine was second hand & everytime we've been using it, it has seemed to work fine apart from a bit of a fizzing noise when you hear power going to the motor to spin the drum, i've not had a hoover before so thought it was prob normal as it was doing its job ok, but last nite cant hear no power going to motor at all & the drum wont spin & the programme selector just clicks as if its running thru the whole programme ok. Could it be the motor brushes that need replacing??
Broken belt check the bottom
Posted on Jun 02, 2008
I've just been given a second hand Daewoo fuzzy logic DWF 4094R. I've been told it works fine, but it has a hose missing. This didn't worry me because I like to do cold water washes. But I
I don\'t under stand what help you need.
If the cat urine smell is outside of the appliance then wash it down with Clorox.
If there is a filter on the output of this machine then service that before doing the next step.
If the odor is inside the machine then run Clorox for a couple of long hot cycles AND then run white vinegar in it. The Clorox will sanitize and the white vinegar will loosen and remove minerals that hold odor.
Add a quarter cup of white vinegar to each load until the odor is gone or your clothes will stink.
My thought is that there is a reason they gave you this "working" machine. If you have further issues then let us know.
Good luck,
Feb 05, 2013 | Washing Machines
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Sep 04, 2012 | Washing Machines
Hi. I just bought a Hoover vision HD 1400 aaa. But i didn't get the user manual, and i am totally green when it comes to washing clothes. i've been around checking out local stores, but nobody seem...
Being from the UK I am amazed that vendors elsewhere seem not to supply manuals automatically with each machine!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | Hoover AAA140 Front Load Washer
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Sep 03, 2011 | Washing Machines
G'day, we've just bought a fisher and paykel wl80
Every one I've worked on a few lately and both of them have had thermistor leaks in to the control board area causing the control board to fail, Sounds like you may have the same problem.. Remove the top control area and check for water. Good luck
May 13, 2011 | Fisher and Paykel Washing Machines
User guide for hoover performa eco 1200
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Washing Machines Logo
109 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
