Question about Sport & Outdoor - Others
I have just purchased a 2nd hand twist stepper BS 1650 and have no instructions re exercise length and frequency, and how to use the digital display. Please help.
5 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: Instructions for mini Reebok side stepper needed
Check here, they can get you every Reebok manual
Posted on Jul 23, 2009
SOURCE: Manual wanted for Kettler Corsa Exercise Bike
http://www.fahrrad-kaiser.de/downloads/1236948801_Kettler_Corsa_02_03.pdf
for free
Posted on Jun 11, 2010
  • 1566 Answers
SOURCE: I purchased a sunny mini
Can you please tell the exact model of the machine?
Posted on Jan 09, 2011
vpsoccer
  • 269 Answers
SOURCE: Hi I have purchased a 2nd hand Colman 431 stove .
I am not sure what to tell you, other than go to Colman's website for a manual. That will at least give you a parts list if you ever need it. But, these stoves are generally solid and reliable, with few things to know about.
What I do to operate:
  1. Set up stove: lid up and wings out, tank fully pumped (works best if no more than about 2/3 to 3/4 full) and installed with nozzle firmly into the socket above the right burner.
  2. Little lever on left of valve assembly--turn upward. Open valve a little bit to get fuel flowing to burner. Give it just a few seconds then light burner with match or lighter (watch your fingers!). It should light off pretty readily.
  3. Open valve a fair bit (anti-clockwise) and let it burn for up to a minute until the flame changes from yellow to mostly blue, and mostly around the burner and not up in the air. Turn little lever on left of valve downward.
  4. Re-pump tank to maintain pressure.
  5. Use valve knob to adjust flame intensity, and cook away.
  6. To use second burner, the key thing os to remember that it draws from the same valve, so when it is on the main burner goes down a bit.
  7. The knob for the 2nd (left) burner is a little flip-out on the left end of the stove. Open slightly, and light the burner. Only do this after the main (right) burner is burning blue.
  8. Use the main valve (on the tank) to adjut the total fuel flow, and the little handle for the left burner to adjust how much of the total flow goes to the left side. (You cannot burn the left without the right being on.)
  9. Pump as required to maintain pressure.
  10. The only real "part" that you might have to strip or replace is the "generator" which is the tube from the valve across the top of the right burner. The liquid fuel is vaporized in there, and is what needs to get warmed up when you start.
Posted on Feb 20, 2011
Que es error 5 tectrix personal climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
Tip
Keypad Test for Stairmaster 4000PT Stepper
Preform this test if you are having trouble entering data into the console. If you cannot enter the DIAGNOSTIC code due to an inoperable keypad, replace the console.
  1. Press [2] to start the test.
  2. The display LEDs will light up in an L-shaped formation, representing the keypad matrix. Pressing a button on either the exercise program keypad or the function keypad will light an LED within the outline on the display that corresponds to that button's position on the console.
  3. Firmly press each button. If the LED corresponding to the button you pushed does not light up, the keypad is bad and the console should be replaced.
  4. Press [CLEAR] to test the LED and then end the test 10 seconds later.
How to Perform Keypad Test on Stairmaster 4000PT
on Mar 10, 2015 | Stairmaster 4000PT Stepper
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
Err 5
Feb 22, 2014 | RTO Tectrix Personal Stair Climber
Screen shows error code 5
Feb 20, 2014 | RTO Tectrix Personal Stair Climber
Screen shows err 5
Star trac sc4100
The following link will take you to the items we have available for your Star Trac SC4100. You can use the tabs on this page to see an owners manual, service manual and a diagram.
Star Trac Unisen Stepper Parts for Star Stepper SC3100 SC4100 SPORTSMITH...
Aug 14, 2013 | Exercise & Fitness
Pedals just go down/they will not go up
This is actually fairly common in home steppers. If you actually try to exercise on it and it does not work, then I would be worried. Can you exercise on it?
If the pedals just go down too fast, then I would increase the resistance.
If the pedals never come up, then you may have forgotten the linkage between the pedals.
Nov 07, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
80 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
