Question about Canon NP 6551 Black and White Copier
Error code: E002 at canon NP6551
We bought lately a used copier Canon NP6551.
But after a few copies he came up with E002.
We let a mechanic come by and he fixed it .
But 2 weeks later same problem. The mechanic came by again , he replaced a small divice with some electick wire on it. he said something from heater.
But 1 week later again same problem.
Please help us, what the real problem could be.
Many thanks , and best regards.
Canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Posted on Jul 29, 2010
  • Canon Expert
  • 1,326 Answers
Techbill is on the right track, but I would say just breaking the contacts on the the DC control may help- that is a good fix for older copiers. How may copies are on the copier? Have you had the copier moved resently? Or have you had some eletric work doe and is the copier on the same power circut with another device (AC unit) ? Also, can the code be reset in service mode, with no new parts put in? I have had the same problem on this mode and other models.... You said the tech replaced something with wires on it... Was it the thirmister? This model has two of them one towards the back of the UFR and one in the middle.. You also, may have a bad front door switch ( AC).... Asks a few questions.....
Posted on Jun 04, 2008
  • 31 Answers
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Posted on Jun 02, 2008
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Jul 04, 2009 | Canon Office Equipment & Supplies
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Error Code: E631 & E632 on Canon NP6551
make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Oct 03, 2008 | Canon NP 6551 Black and White Copier
Please help
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Jul 08, 2008 | Canon NP 6551 Black and White Copier
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Canon NP 6551 Black and White Copier Logo
1,077 people viewed this question
old marine
old marine
