Question about Kyocera Mita Office Equipment & Supplies
Hi, my KM1820 displays error c3200. The exposure lamp will light up brightly but will turn off after the error code is displayed.. The error happened after I cleaned the scanner mirrors. I did this by manually moving the scanner unit towards the center by revolving the gears. But the unit was switched off.. After I restored the mirrors and the exposure lamp, I switched on the unit. When i press the green button, the error was dispayed. please help
  • 10 Answers
SOURCE: Error Message
normally flicking the transportation lock on the scanner open and locked a few times and leaving it in the open position works.
also you can download a better version of scan software, mine works fine now.
TWAIN Driver and EPSON Scan Utility v3.04A
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14082&prodoid=24875245&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=25&y=8
Posted on Nov 30, 2007
SOURCE: Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Posted on Mar 11, 2008
  • 10 Answers
SOURCE: scanner bulb warming up message!!
Aqeel,
This is the problem with your scanner. If it is under warranty please take it to Hp Service center and they will replace it free for you.
Thanks
Posted on Aug 16, 2008
SOURCE: scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
Sir I have Minolta biz 600 error c-6708
If this code comes back have to replace the CCD or the exposure lamp. both located under the big glass. The Black device under the glass to your right is the CCD and the exposure lamp is bright light to your left which turn on when you scan
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 21, 2017 | Minolta Office Equipment & Supplies
I have kyocera km1500 and have error A3200 .what is the solution?
Hi
A3200 is not a known error in the service manuals, maybe it's C3200?
Code
C3200
Description
Exposure lamp problem
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Causes
Defective scanner board (KP-5063). Defective exposure lamp or inverter board. Incorrect shading position. Poor contact of the connector terminals.
Jul 24, 2016 | Kyocera Office Equipment & Supplies
Please my heater lamp is not lighting.
U need to check whether the exposure lamp is light ON or not when u turn ON the machine
If not light ON, then exposure lamp unit or connectors might be faulty
Dec 21, 2015 | Toshiba E-Studio 160 All-In-One Laser...
I have a minolta Photocopier CSPro EP1080 that keeps displaying an error message; C04 with a Spanner sign as well, what will I do?
Exposure lamp is burned out or the board the operates it is or both. The exposure lamp is the very bright light hat comes on when you make a copy under the the big sheet of glass. Raise the document feeder up and press start button does the bright lite come on and scanner move?
Try to reset. power off the machine, remove the top rear cover. Find the main circuit board now turn on the machine wait for code to show up and press the small black button on board lower right. if the code comes back try below parts.
Try this site for the lamp as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 10, 2015 | Minolta Office Equipment & Supplies
How to fix error c9401
Exposure lamp failure to turn on, raise the doc feeder hit the start button bright light come on under the big glass if not replace the exposure lamp and board if required.
reset procedure if code comes back get the lamp
May 20, 2014 | Konica Minolta Bizhub C300 All-In-One...
Whats the problem if code C04 come from Minolta EP1083
The error code is displayed in 2 section on the display on the zoom dosplay and the number display.
C0400 Exposure lamp malfunction.
C0410 Exposure lamp thermistor malfunction.
Verify the exposure lamp continuity and the thermistor continuity.To reset error code open the copier and press the reset microswitch located on the rear PWB panel ,close the machine front door.
Jun 02, 2013 | Office Equipment & Supplies
Error c3200
C3200 is an exposure lamp problem. The simplest explanation would be a bad exposure lamp or inverter. More exotic, but still possible, is very cold environment, dirty AC power, a bad CCD, or a bad main PCB.
Jan 29, 2013 | Kyocera FS-1118MFP Laser Printer
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
Error mesege Showing E1
The E codes E1-E7 are displayed in the copy counter.To display both digits of the E code press the ENTER key.When the machine detect E13 condition E1 is displayed in the copy counter.Hold down the enter key and 13 is displayed.
E 11 - Exposure lamp error.In this case check the exposure lamp continuity,the thermofuse is open or power suplly board defective.
E 12 -Exposure lamp error .AC drive defective,main board defective
E 13 - Zero cross signal error.Main control or DC power board defective.
To clear the service code turn OFF/ON the machine.
Sep 09, 2009 | Ricoh Office Equipment & Supplies
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
180 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
