Question about Intermatic ET70115CR Electronic Energy Control Timer Single Circuit SPDT 12
Do not have manual to assist in reseting timer
  • 12,061 Answers
Http://www.retrevo.com/support/Intermatic-ET70115CR-manual/id/22965ag823/t/2/
Hi, please find above a user manual, I hope this helps you sort your problem out.
If necessary you may need to obtain a service and repair manual, you could obtain this from Intermatic, direct. I have searched the 'net, but wasn't able to locate one.
Direct Link below...
www.intermatic.com/ - United States
Posted on Oct 14, 2010
Timer switch instructions
Copy following link to help identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add comment and describe timer in detail for possible assistance
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 22, 2013 | Hardware & Accessories
Unable to set timer
Reset timer.
Change battery.
Copy following links to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add comment and describe timer in detail for possible assistance.
Mar 31, 2013 | Hardware & Accessories
How do I reset the Polder Clock Timer - the narrow white one which has clock, count up and timer?
Timer is not identified for certain
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical manual says to hold down clock button for 3 seconds until display disappears.
Another part of manual says to press start/stop then clear to reset timer to 0:00:00
Another part of manual says to press clear to reset timer back to 00:00:00
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 27, 2011 | Polder Triple Digital Timer Model 891-90
How to reset lamp timer? I changed new lamp and i don now how to do reset timer help please and i dont have manual book,thank You
1) Add a comment with photo of your timer so I can see it:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Open following link to identify same-similar timer and download manual:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Apr 12, 2011 | Hardware & Accessories
Does this timer go one and off everyday or just one time/' untill you reset it again
I do not have a manual for GE 51583 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#51583
Generally speaking, programmable timers are set one time, and then they repeat that program day after day until timer malfunctions or you reset programming.
If your timer is resetting itself, then electricity might be going off, for example a loose wire?
Try timer on another outlet.
Test outlet with cheap circuit analyzer from home center.
It is hard to answer question without guessing until I can read the manual.
If you have instruction manual, I would enjoy getting a copy.
Scan manual page(s) into jpeg/jpg format to your computer and then add a comment with those photos so I can see instructions.
Add a comment with your experience so others with same-similar problem can benefit.
Mar 27, 2011 | GE 51583 24Hour Digital Indoor Timer
Just installed the programmable timer and had programmed the clock and on off times. Then realized that it was set for AM instead of PM. Hit reset and now can't set the clock or program. Just blinks...
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Mar 20, 2011 | Woods InWall 7 Day Digital Programmable...
Even with new battery, on-off will not click
1) If timer worked before and stopped working, then manual says last step is to reset timer.
If timer will not function after reset, then timer is broken.
2) You posted under battery-operated ST01C timer, that comes with 1 year limited warranty.
Open following page to identify timer, read ez instructions, and download on-line manual
http://waterheatertimer.org/ST01C-program.html
3) How to reset ST01C
Hold down on-off button and press reset button
Release reset button.
Keep holding down on-off button until INIT flashes on screen.
Release on-off and 12:00 will flash
Re-program timer using ez steps shown on link above.
Mar 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a timer for a lamp outside it is making a loud buzzing sound even when turned off.Is there sometime that i can do to stop this?
You timer is buzzing.
Try changing light bulb > sometimes these timers malfunction when there is line interference.
Try resetting timer with reset button.
Some timers require holding down on-off button while pressing reset button.
Check your manual.
If you don't have a manual, open following link to help identify your timer and download manual.
http://waterheatertimer.org/Programmable.html
If resetting timer does not solve problem, you might need new timer.
Most timers have 1 year limited warranty.
New one can be purchased at local home center.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Hardware & Accessories
My TM-014 Timer is not sending power out on any of the settings, on, off, auto or rdm.
I cannot identify TM014 timer in any of my timer files.
1) If timer is having a problem, then use reset button and start over.
2) Add a comment with exact description of timer so I can find same/similar timer and read manual alongside you.
3) Open links below for additional do-it-yourself assistance
a) You posted under GE timers.
GE does not have that timer number:
b) Utilitec sells 0149289:
http://waterheatertimer.org/Woods-timers-and-manuals.html#TD22
4) Add a comment for more free help.
Feb 17, 2011 | General Electric Hardware & Accessories
Used a single prong 8 setting hamilton timer for a bout a year and the lcd isnt working and it runs continuously.nothing lights up in lcd area.
Usually when digital timer has problem, last resort is to reset the timer.
Most timers require you to hold a button and then press reset button.
I do not have this manual and cannot say what reset procedure is for certain.
Also, would you please scan your timer manual and then post the .jpg or .doc file on your website or on imgur.com.
Then add a comment to this thread with web address of that manual.
And then next fixya customer gets best possible free answer on Hamilton timers.
Feb 15, 2011 | Hamilton Electronics Hamilton 24hr Digital...
Intermatic ET70115CR Electronic Energy Control Timer Single Circuit SPDT 12 Logo
44 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
