Question about Compaq Presario Notebook
Compaq Presario Laptop ERROR CODES
Laptop will not boot up. Error code is (PXE-E61) Media Test Failure Check Cable. I checked the cable and even re-inserted it to the mother board and still get the error code. The front panel led hard drive light comes on but still receives error code. I tried several known good drives and still same error code. Could it be a bad removable header connector that connects onto the pins of the hard drive?
  • cameronmarti Mar 15, 2009
    on boot my laptop freezes and when i run a hard disk self ong test it says "failed - replace hard disk 1 (warranty ID - error code 10008" what can i do to resolve this ?
  • MIKE WESTBURY Sep 16, 2012
    what exactly does failure id: 9CX2K1-5HF681-XDO141-6ORCO3 MEAN. MY LAPTOP WILL NOT BOOT EITHER. IS THERE ANYTHING I CAN DO?
On boot into post select F10 enter the bios - correct boot order to dvd 1st hdd 2nd and fdd as 3rd boot devices - highlight network boot and hit enter then disable boot from network the hit F10 to save and exit unit will boot from dvd unit with recovery dvd disc installed
Posted on Mar 03, 2009
    Problem Solver:
  • 5 Answers
PXE-E61 error.
1. Start the computer and click F12 to give you the boot-up options.
2.Insert Windows Installation Recover Disk into CDROM and choose CDROM boot option and click enter.
3. When it prompts you to press any key to boot off the CD, hit the spacebar and initiated the process.
4. It should go into Windows setup mode with a blue screen, wait for everything to load-up until it gives you the option to "Repair" click 'R' and it goes to DOS mode.
5. Type in FIXBOOT and and when prompted press "Y" to start creating a new boot partition.
6. A message should appear (shortly) saying the partition was corrupted and a new one was created successfully.
7. Remove the CD type EXIT to leave Windows set-up and reboot the computer. Computer should go through it's normal sequences in loading up windows.
Posted on Jul 03, 2008
  • 2,785 Answers
It is a hard drive problem plz try with another hdd
Posted on Jun 02, 2008
    Problem Solver:
  • 5 Answers
Well I thought I had known good hard drives when I tried them and it turned out to be not the case. When I tried with another hard drive that turned out to be good the problem was eliminated and I was able to install a XP Pro OS with no problems and of course I was able to update the drivers needed for the sound and video applications. All is working very well and surprisingly fast for this 1.3 Ghz Intel Celeron M CPU based laptop. Thanks for the quick response anyways.
Kevin Leitch
Posted on Jun 10, 2008
5 Suggested Answers
  • 1879 Answers
SOURCE: PXE-E61: Media test failure, check cable
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Posted on Aug 31, 2008
  • 32281 Answers
SOURCE: GETTING ON MY LAPTP: PXE-E61: Media test failure, check cable
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
Posted on Jun 28, 2009
  • 3153 Answers
SOURCE: aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Posted on Sep 28, 2009
Testimonial: "I found an internal disconectet cabel fixing it solved the bootproblem"
  • 3940 Answers
SOURCE: PXE-E61 : media test failure,
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Posted on Jun 17, 2011
Computer wont boot error code pxe e61
You must initialize the new hard drive first.
Jan 28, 2014 | Toshiba Computers & Internet
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
Wile I am trying to boot it up it goes in to a loop
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Argon PXE Boot Agent v2.01 2002 - PXE - E61
Your computer tries to "boot" from several devices:
* floppy-disk
* disk-drive
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Jun 03, 2009 | Compaq Presario 2100 Series: 1170B01-90...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Compaq Presario Notebook Logo
4,620 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
