Question about Nokia 6233 Cellular Phone
My radio not connecting. - Nokia 6233 Cellular Phone
My volvomodel VR400 audio radio will not receive any kind of radio station. radio comes on will play cd,s and cassettes, but no radio stations. everything appears to be hooked up. When I turn radio on
If you are certain that your rad. & ant are not def., then you should check the ant.cable. Also, make sure your radio has a constant hot, and check to see if you have a hot wire at the ant. that comes on/off with radio.
Feb 10, 2015 | Car Audio & Video
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
Why have I no radio reception on peugeot 307?
go step by step to find the fault.
check antenna connection behind the radio
check roof aerial and wire connection underneath it.
Take an old radio's antenna and connect it to your car's radio antenna input and check whether your car radio is working properly.
Apr 15, 2012 | Peugeot 307 Cars & Trucks
Can i connect a Uniden UH089NB UHF 2way radio to 12 & 24v
Hi John,
Page 5 of the manual for this radio specifies a 13.8 VDC (12VDC car / truck electrical system) power supply to power the radio.
Connecting to a 24 VDC system will damage the radio and likely require expensive repair or replacement.
Feb 01, 2012 | Uniden Radio Communications
How do I connect Sirus XM for a 2006 escape using the audio cable? Does my radio have an input jack?
You will need to remove the radio and look at the rear for the input, if your radio doesnt have an input you can buy the kit to connect it to sirrus and instead of direct connect you can use a radio station to connect to sirrus,most newwer cars and trucks will come with an input but lower brand radios may not. the only way would be to remove the radio and check , dont reinstall radio if you plan on getting the adapt kit.
Dec 23, 2011 | 2006 Ford Escape
Radio is on but display is dimmed
Maybe, your radio is having problem with the connection. Check the connection of your radio whether it is properly connected or your give your radio to a repairer for proper servicing. So, the problem is of two types, (1) Connection of the radio to your car or (2) The radio needs to be serviced.
Sep 21, 2009 | 2000 Toyota Avalon
Radio display lights stay on after power is cut from engine and key is removed from ignition. Radio buttons fail intermittently
the radio sounds as if they are connected to a constant power supply as well as if that's not the case a faulty radio connection or radio itself is present look to see where the radio lead wire is connected to
Sep 15, 2009 | 2006 Hyundai Elantra
2003 Mercury Grand Marquis radio reception problem
check the back of the radio, make sure than the antenna, connector is plug into the radio, if it is, then replace the radio.
Jul 30, 2009 | 2003 Mercury Grand Marquis
Imy bikedoes not have the female radio connection
Bikes sold without radios were not delivered with wiring harnesses installed. Be sure you also have the handle bar controls to control the radio. Not all functions are on the faceplate
Jul 29, 2009 | Harley Davidson 426290 AM/FM Radio
Radio connection..
You need to have two type of harness one goes to your factory harness. The other one it goes to your radio so 2 different one's.
Mar 24, 2009 | 2001 Ford Expedition
Nokia 6233 Cellular Phone Logo
14 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
