Question about Cameras
My flash is taking 30 sec or more to recharge
    Brigadier General:
  • 11,967 Answers
Sounds like weak batteries.
Posted on Oct 14, 2010
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Sep 20, 2014 | Canon EOS-20D Digital Camera
I have sx100 camera. when i am using to take a picture with flash i cannot take the next picture immediately. some times it take more than 30 sec. without flash no prob. this is not a memory card problem.
It depends on your battery condition, flash capacitor will charge faster if battery is freshly recharged. Or battery has larger current capacity. You can shoot pictures with flash faster if its fill-in or closer in distance. Which means capacitor recharge is not totally depleted for each flash duration.
Aug 26, 2010 | Canon Cameras
Will not drain.Light flashes for aprox 30 sec then
If you have your user manual for the dishwasher than it will tell you what the code means. Youd garbage disposer is probable plugged up or was changed recently. Try taking off the drain hose that is under you sink that goes to the garbage disposer. Look at the disposer and see if the plug is punched out or not. To punch it out take a screwdriver and hit the end with a hammer inthe hole. It its not pluged, try blowing out the hose backwards with compressed air. Also all dishwashers have some sort of filter system that is accessable inside the machine. Thr taking that off and cleaning it.
Feb 05, 2010 | Hobart Dishwashers
I left my phone on and it ran down. I have
Try taking the battery out plug the charger in, wait 30 secs then put the battery in with the charger still pluged in, wait 10 secs then try to turn it on again. if it turns on perfect if not, u could try another battery. if all else fails take it to your service providers repair center
Dec 03, 2009 | Samsung Eternity Cell Phone
What is the time it takes for a panasonic lumix lz10 camera to store an image that is captured and get ready for the next image capture?(with original transcend sdhc card 4GB)
I actually own one of those ...( and Im satisfied ) and indeed its a little slow when you set it for taking large pistures size ...a mean more than 4M ...but I keep it on 2 M size max ..and it store the pic in about 2 secconds..or less ...so if it seams to you that its something wrong with it ...stay calm cause this is the way it work ...it takes about 2 sec to store and recharge the flash ...I believe that recharging the flash takes more and storage its actually almost instant ...but I never try it without the flash ...
anyway beside the fact that it has poor capacity when it cames to power (limitated by the 2 batheries only )..its great ...
Sep 29, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Pentax S40 Lag Time
It's definitely painful. I set my camera to default to no-flash because of the extra time it takes to recharge the flash. It may be because Pentax allows the use of alkaline batteries, so they've made the peak power usage lower by processing the picture, writing to the card, and recharging the flash sequentially, rather than doing the flash recharging in parallel which would speed up things *alot*. Maybe they can add a Lithium/NiMH mode that would help speed things up?!? I've done some adhoc testing with my new panasonic 10mb/s SD card versus a plain jane Sandisk 2mb/s card and from what I can tell, there's less than 1 sec difference between the two cards in cycle times. So taking pictures with a faster card won't help the cycle time enough to really matter... even without the flash activated. With flash it doesn't matter at all. It may affect movie mode, but I haven't tested that yet.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
