Question about Dell E173FP 17" LCD Flat Panel Monitor
My screen image has been rotated 90%, I now have to lie down to see what I am doing... any ideas what to press to turn it back>
    Master:
    Sergeant:
  • 460 Answers
You can adjust again by alt+del+arrow keys.
Posted on Oct 14, 2010
My login screen has turn upside down
Is it only your login screen? or is it the entire operating system? Does it fix after you log in?
Press [Ctrl > Alt > Up arrow] (all at the same time) to revert back to normal orientation. If it is only the login screen, then it may be a issue with the Operating System.
Aug 28, 2011 | Advent Netbook
I turned my screen up side down and cant turn back what can I do
Firstly log on to the computer and get in the main/desktop screen
now press and hold the "Ctrl" key, the "Alt" key and the right arrow key togather .. the screen will rotate. Keep hitting the right arrow key on the keyboard with the Ctrl and the Alt key pressed unless the screen is back to normal.
If it does'nt work you can also try this:
Go to Start>> Control Panel>> Display icon>> Settings tab>> Advanced button>> Intel(R) Extreme Graphics tab (or whatever your video card is)>> Graphics Properties button>> Rotation tab.
It should work
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 20, 2010 | Computers & Internet
HP 1740 screen image rotated 90 degrees - how to move back
On most video cards the key combinations of ctrl+alt+left arrow, ctrl+alt+right arrow, ctrl+alt+up arrow or ctrl+alt+down arrow will allow you to rotate the screen display in any direction. Each key combination will rotate the screen in the direction of the key press.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 23, 2010 | HP Pavilion F1703 17" LCD Monitor
There is green line in lcd screen thet will devlop or not
One of the chips at the top of your screen is faulty
and you can't fix it,Sorry.This may hellp tho.....
READ CAREFULLY FIRST BEFORE STARTING
Removing the screens bezels will void warantee
In Saying that ,
Heres how I would do a screen replacement,
You will need a small philips screwdriver for this ...
Remove the power and battery
To Remove the bezel from the front of the screen
There should be 4 or 6 screws holding the cover on,
Screws may be covered by rubber buttons,
then remove the screws holding the LCD to the hinges' frame.
Tilt forward your LCD and lie screen on your keyboard
LCD panels have a row of IC chips at the top that produce the images on your LCD so do not touch or flex this area because it may produce lines on the LCD or kill it completely.
botom of screen is inverter power and plug to screen
top rear of LCD is video feed from motherboard,
(above that are those important IC Chips-
DONT TOUCH THE CHIPS)
LCD wiil have tape fastening plug to the socket,
Remove tape and this will expose the plug.
Un plug from screens socket,
Reseat plug back into socket,
Put Tape back on to stop any unwanted movements,
Next step is to power up the LCD to test.
Rest LCD in back of lid and lie lid on table with base at 90 degrees for access to plug in AC power.
do not use battery for this test.
Turn ON power,
If it starts up, then you have a running machine again,
Shut down , unplug power and reassemble,
If LCD does not start then you need to replace the LCD panel and thats about all you can do,
Hope this helps.......
Cheers MisterdJ
Apr 13, 2010 | HP Computers & Internet
I have Acer Laptop suddenly now the screen remains blank even after switching on the laptop. Actually as I was surfing the net suddenly the screen display color changed and later I thought there is...
if you can see the start up screen in full color when it starts then the last update could have caused it,
But its more likely that the plug inside the back of the LCD has come loose and needs to be replugged back in,
In Saying that ,
Turn ON power,
Cheers Misterdj
Apr 12, 2010 | Acer Aspire 4520-5582 Notebook
Hp monitor
> how do I fix ?
Keep any "pranksters" away from your computer. :-)
The software for your video-card has an option to "rotate" the displayed image, either 90 or 180 or 270 degrees. Some "prankster" has set your video-card to the '180 degrees' setting. Change it back, or turn your monitor upside down. :-)
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Desktop has rotated 90 degrees
keep pressing ctrl&alt and press upper arrow key
Apr 05, 2010 | HP w1907 LCD Monitor
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Screen image rotated through 90 deg.
Hello , friend
Please do this shortcut
ctrl + alt + arrow keys
Jul 26, 2008 | Lenovo ThinkPad T61 Notebook
How can the image be rotated?
To rotate a vertical image, display the image in playback mode, press the down key to cycle through the three positions: 90 degrees counterclockwise, 90 degrees clockwise, and horizontal. Upside down position is not available.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Dell E173FP 17" LCD Flat Panel Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
