Question about Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher
My Bosch Dishwasher does not drain all the water out of the dish washer after the finishing cycle...I usually start the washer and then push the drain cycle and it starts to pump for about 10 seconds and stops and starts and pumps again for 10 seconds and stops and then pumps for about 25 seconds and stops....doing this manual drain twice empties the dishwasher of the excess water....what may the problem be?
SOURCE: Bosch dishwasher
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Feb 20, 2008
SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Posted on Mar 27, 2008
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
Dish washer goes through cycle but when finished cold with Code E..09
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Have bosch SHE45 EVOLUTION PUSH BUTTON ON RIGHT FRONT PANEL. MY WASHER WILL NOT RINSE ALL THE SUDS OFF THE DISHES OR DOWN THE DRAIN AND HAD BAD SOAP RESIDUE BUILD UP. i HAVE USED LEMISHINE ONE TIME AND...
I started running the Hot water faucet till I got really Hot water then I started the dishwasher with No dishes in it and let it fill with hot water till it was almost full then I added a half a gallon of white vineagar to the water and let the dishwasher go through its cycle. It cleaned up the inside of my dishwasher then I put the dishes that didn't get clean and that had a soap film on and rewashed them with plain hot water and poured the other half a gallon of vineagar in the dishwasher and let them wash the complete cycle. It cleaned the dishes very well. I don't know if you will have the same results but it worked for me..... Hope this helps, your welcome to give it a try vineagar is pretty cheap... and it won't hurt anything inside the dishwasher or dishes.
Feb 12, 2011 | Dishwashers
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher Logo
159 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
