Question about Bosch KFU 5755 Refrigerator
Bosch KFU 5755 unit is leaking from LH side under freezer unit
Bosch fridge freezer: Oil substance- like corn oil/ olive oil - puddle of this appearing on floor under freezer section. cannot find any source for this. Is it likely to be a leak from the black tank unit...
The oil like substance could be coolant, but it could be something else. If the compressor has developed a leak you won't have that long before it goes, and you will notice the compressor getting hotter and hotter before it just totally locks up.
BUT are you sure that the oil like substance is coming from the compressor and not the coolant line? If it is the coolant line that can be repaired and the unit charged with coolant as long as the compressor hasn't locked up due to low coolant. SO I would attempt to localize the leak the best you can.
Jan 07, 2012 | Refrigerators
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
Mar 23, 2011 | Bosch Appliances 20.19 cu. ft....
Water is leaking from inside the freezer side of
water drianage is normal, it is supposed to drip from the freezer area to a drip pan under the unit and evaporate before it gets full. check to make sure that the drip pan is properly located and exsits and that you do not have an obstruction hindering the drain opening
Aug 22, 2009 | Hotpoint Refrigerators
Every day, some water appears on the kitchen floor. It appears to be leaking from somewhere in the freezer side of our side by side frig and freezer. Latter has automatic icemaker and water server in...
Your evaporator drain pan under the fridge may be misplaced. If so, simply pull out the unit and place the pan back where it goes under your box. Hope this helps!
Aug 16, 2009 | Refrigerators
Bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Jul 26, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
Bosch KFU 5755 Refrigerator Logo
110 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
