Question about Alpine CDE-9852 CD Player
CDE-9852 hey i took out my old aftermarket stereo and decided to install the CDE-9852, i wired everything up correctly but when i go to turn my car on nothing happens, i checked the plug and its giving power also has a ground on the black wire, but for some reason it wont work, got any ideas? i drive a 96 honda accord lx thanks -Anton
Probably the mode you are in, there is a mode for auxillary amplifier that disables the internal pa, in the aux amp mode you won't hear anything.
slonis
Posted on Jul 12, 2008
Is 1998 taurus compatible with alpine cde-9852
Hello, you can install this head unit into the taurus as long as you are confident in wiring the unit in yourself. the colour wires from the car WILL NOT match the colours from the CD player, although a experienced installer will be able to splice the wires together in the orrect way to make it work!
I hope this helpsRegardsGrant
Nov 19, 2011 | Alpine CDE-9852 CD Player
I need to what are the red ,yellow ,orange,blue,&blue/white wires are on my alpine cde 9852
red Acc yellow 12volt blue power attn blue white remote turn on orange is not needed www,geeksquadkieran@yahoo.com plz e mail me if needing more info
Jun 30, 2010 | Alpine CDE-9852 CD Player
When i turn my car on, the head unit doesn't turn on automatically so i have to use the power button. all the preset stations get reset too.
the unit is most likely not installed correctly, make sure the yellow wire has 12v at all times and the red wire has 12v only when the acc or ign is on
Jun 07, 2010 | Alpine CDE-9852 CD Player
Dead Alpine CDE-9852 Stereo
its the fuse behind your deck( Alpine unit has its own fuse) YOU WILL NEED to remove your deck to access this fuse
Jan 16, 2010 | Alpine CDE-9852 CD Player
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Adjusting the time on an Alpine CDE-9852
Hello bitterswe834,
To set the time, do this:
1. Press TITLE repeatedly until the time is displayed.
2. Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3. Use the volume control to adjust the hours while the time indication is blinking.
4. When the hour has been adjusted, press MODE.
5. Turn the volume control to adjust the minutes while the time indication is blinking.
Hope this helps.
May 24, 2009 | Alpine CDE-9852 CD Player
Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
Apr 21, 2008 | Alpine CDE-9852 CD Player
CDE-9852 turns off when driving
check your power wire (big yellow wire), your ignition wire (red) your ground wire (black) to the deck it could be a loose connection due to vibration or corrosion
hope this helps
Mar 31, 2008 | Alpine CDE-9852 CD Player
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Alpine CDE-9852 CD Player Logo
137 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
