Question about Casio fx-300ES Calculator
How to get a decimal answer? - Casio fx-300ES Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Posted on Oct 14, 2010
How do I get answers in decimal format because when I divide I get answer in improper fraction format
You must insert decimal point in equation to get a decimal point in the answer. whole numbers only give whole number sums.
May 22, 2015 | Office Equipment & Supplies
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
When I enter 55/2 - the answer appears as a fraction. I would like for it to appear as a decimal. I know I can convert the answer using the SD key, but I would like the initial answer as a decimal.
To get the result in decimal format, press [SHIFT][=] instead of just [=].
You can also configure your calculator to show only decimal results:
  1. Press [SHIFT][MODE] to access the (SETUP)
  2. Select [2:LineIO]
Aug 12, 2010 | Casio FX-115ES Scientific Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Convert 4 2/9 to a decimal
Step 1: Find a number you can multiply by the bottom of the fraction to make it 10, or 100, or 1000, or any 1 followed by 0s. Step 2: Multiply both top and bottom by that number. Step 3. Then write down just the top number, putting the decimal place in the correct spot (one space from the right for every zero in the bottom number) Example 1: Express 3/4 as a Decimal Step 1: We can mulitply 4 by 25 to become 100
Step 2: Multiply top and bottom by 25:
×25 left-up-over-arrow.gif 3 = 75
4 100 left-under-over-arrow.gif ×25 Step 3: Write down 75 with the decimal place 2 spaces from the right (because 100 has 2 zeros);
Answer = 0.75
Example 2: Express 3/16 as a Decimal Step 1: We have to mulitply 16 by 625 to become 10,000
Step 2: Multiply top and bottom by 625:
×625 left-up-over-arrow.gif 3 = 1,875
16 10,000 left-under-over-arrow.gif ×625 Step 3: Write down 1875 with the decimal place 4 spaces from the right (because 10,000 has 4 zeros);
Answer = 0.1875
Example 2: Express 1/3 as a Decimal Step 1: There is no way to multiply 3 to become 10 or 100 or any power of 10, but we can calculate an approximate decimal by choosing to multiply by, say, 333
Step 2: Multiply top and bottom by 333:
×333 left-up-over-arrow.gif 1 = 333
3 999 left-under-over-arrow.gif ×333 Step 3: Now, 999 is nearly 1,000, so let us write down 333 with the decimal place 3 spaces from the right (because 1,000 has 3 zeros):
Answer = 0.333 (accurate to only 3 decimal places !
Sep 22, 2009 | Black & Decker Juicers
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
I want the answer to be in decimal form.
Press "MODE"
then scroll down to "Exact/Approx"
select "approximate"
this will have your answers in decimal as default
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
