Question about Samsung S860 Digital Camera
The lens stocked, how can i posibly fixed it my own
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 14, 2010
Samsung es30
If the spot is in all foto's and in a video, it is most likely not the lens. Could be a dead pixel (some pixels). But almost certain a spec of dust or othes debris that entered the camera.
Because this camera came with a fixed zoom lens, there is no sensor cleaning option. And I can't find a posibility to make a dust retentie picture.
To check if the spot is on the sensor, put the camera in manual, set aperatur to the greatest figure (smallest opening) an make a picture of a white object. If you see the spot, you were spot on. When the camera is new, this could be a reason, to go to your dealer and ask a new camera. Take the dust retentie picture with you.
Oct 31, 2013 | Cameras
Sony camera sea water damage and wet
Highly unlikely that it can be repaired, salt water caused corrosion and will short out electronic components when the battery is connected.
I suggest you put your money towards a new camera.
Oct 20, 2012 | Sony Alpha NEX-5 Digital Camera with...
I drop my sanyo camera the lens is stock
If you look at the lens assembly, it is likely out of place. This is often the case with many 'point and shoot' cameras and in often cases the lens assembly needs to be replaced. Frequently however the lens assembly repair ends up costing more money than a new camera itself. You can attempt to contact precisioncamera (google it) or a local camera repair place and see what they would charge you to fix the lens assembly. But in my experience it normally cost more to repair one of those cameras than replace it.
Mar 02, 2011 | Cameras
I put my disk in the console and turn it on, but it says there is no data. The disk wont even rotate. How can i fix this.
posible reasons
1. disk have too many scratches that unable to ready. try to clean the cd
2. lens problem, clean the eye of the llens carefully.
Nov 25, 2010 | Sony PlayStation 2 Slimline Console
My picture is very blurry and often freezes. What could be the reason?
BLurry...
1. you may adjust the focus of the camera by turning lens left or right..
Freeze problem Posibilities
1. Posible driver problem. REinstall the camera driver
2. Your Computer memory is low..
3. Display driver is not updated..
Jun 13, 2010 | Mri WebCam
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Lens is not moving in or out
Two posibilities : lens impacted and has to be replaced complete ( the whole lens unit with both motors and CCD sensor ) this is expensive. Or is you are lucky the gearbox has a gear that has popped. Replacing gearbox is not so expensive.
Sep 02, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Lens Error
Two posibilities : either the gear box needs attention or the lens itself is impacted . The first problem is not so expensive to sort out by your repair outfit but the impacted lens problem is expensive ( may require replacing lens assy. ). Anyway camera has to go in I am affraid.
Aug 24, 2007 | Kodak EasyShare C643 Digital Camera
Samsung S860 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
