Question about GE Televison & Video
Tv dont have volume. it comes on and and shows perfect picture what should i do. is there a reset button on it?
  • 10,865 Answers
Hello. Turn on the TV then enter the menu and find the audio area. There you will see a master volume control. Increase that setting until you are happy with the results. Joe
4 thumbs up please for this spot on and free answer. thanks.
Posted on Oct 14, 2010
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
My picture is perfect but I lost volume how do I get volume back
You may have turned the tv's speakers off. check your menu to see if thats the case.
Feb 05, 2015 | Protron PLTV-4250 42 in. LCD Television
Plz i need master password for itel it6300...imei no..358288050239069..i forget my password..plz.
1. Turn off the phone 2. Press and hold the power button and at the same time the down volume button 3. When the itel logo appears, press and hold the home button. 4. Release all buttons once you see the yellow warning sign and the picture of a phone. 5.Press the up volume button once, then use the volume down button to navigate to select wipe data /factory reset then use the power button to confirm your choice accordingly. 6. Use the down volume button to select yes -- delete all user data, then use the power button to confirm. 7.Use the power button and select reboot system now, You are done Wait for your phone to restart.
Read more: What is the common factory reset code for all itel mobile handset? - I received an `itel` mobile phone from a friend as a gift. problem is i dont know the exact type since it did not come with the box. every indication on the phone shows that it being tampered with in terms of the settings. now all i need is THE FACTORY RESET CODE to set the phone back. thank you. am newton from ghana west africa :: Ask Me Fast at http://www.askmefast.com/What_is_the_common_factory_reset_code_for_all_itel_mobile_handset-qna2535929.html#q6008773
Oct 31, 2013 | Cell Phones
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
RCA Guide Plus Gold Gemstar 27 inch Entertainment Series has perfect picture no sound. The speakers are ok have tested them. When tv is turned on and dvd player is on shows perfect picture but can only...
On the left hand side of the remote control there is a blue or diferent kind of small sercle round buton (mute) push it once and turn the volume up till you hear the volume.
Nov 06, 2009 | RCA Televison & Video
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
35 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
