Question about Sigma Sport BC1106 Dts Wireless Bike Computer
Hi The pictures in manual docent show the direction clear . The magnet and the trnsmiter.
  • 186 Answers
Magnet gets screwed or clipped onto the spoke.the transmitter attaches to the fork.make sure the magnet on the spoke passes the centre of the transmitter (should be a mark on the transmitter)and also make sure the magnet passes the transmitter with 3 to 4 mm gap.you may have to turn the transmitter alittle to get it closer to the magnet.hope this helps
Posted on Oct 14, 2010
Grundig TV - Colours all mixed - still have fullpicture
Hi rosscop
You have a magnetic interference problem. First, have you put any magnetic objects like speakers near the set recently. They will cause this. Turn the set off at the wall and wait for 15 mins for the PTC device that turns on the degauss coil to cool and operate. It is the loud burst of hum you here when you turn the set on from cold.
0083efa.jpgThe PTC is a postive tempeture coefficient that allows alot of current to flow at first, heating up as it does, and then slowly less current as it heats. This is why you need to turn the set off and let it cool. If the problem remains The PTC may be faulty allowing too much current to flow and upsetting the magnetic flux about the tube. If you dont have the skills you will need a technician to sort it out for you.
Aug 25, 2008 | Grundig GF70-600 TV
Magnet came in contact blue green and red color
Every time you turn on a color TV, a degaussing circuit tries to neutralize magnetic fields on the picture tube face that can cause distorted colors. That degaussing circuit isn't strong enough to clear up the field left by direct contact with a magnet. You need an external degaussing ring to clear up the funny colors. You can see what one looks like here. You might be able to find one for sale on eBay or borrow one from someone in the TV service business. Or you can take the TV to a shop where they can degauss it for you for a small charge. Just be aware there's a chance the picture tube may have been damaged if the magnet was very strong and was in contact with the tube for any length of time. A thin metal screen called the shadow mask is behind the tube face, and if that was warped by the magnet then the colors will never line up correctly again. If this has happened, even after degaussing the colors will still be wrong. But you won't know until you try. Good luck, and thanks for using Fixya!
Jun 02, 2011 | Daewoo DTQ-27S5FC 27" TV
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Display shows OP but unable to clear , checked out switch, 1 contact pin was heavily corroded. I polished it up but made no difference
If you place a magnet over the left hand grey bumper will this clear the OP error code with the washer lid up? If so you have a lid magnet out of position.
See page 35 of the FAV6800A/FAV9800A Service Manual for the location.
Did you remove the left hand lid lock cover and inspect the connections on the magnetic reed relay?
Check to see if the leads on the magnetic reed relay are connected. This pic shows the black lead broken from one end of the magnetic reed relay. This will produce loss of signaling to the Control Board and generate an OP error code.
See this link for Left Hand Lid Lock troubleshooting http://www.fixya.com/support/t3124779-od_alarm_neptune_tl
I discuss troubleshooting for the OD error code. You troubleshoot the OP error code in a similar fashion.
Rich
Jul 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The OD code will not clear
od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock and or lid magnet issue.
First check to see if you can clear the od error with an external magnet as shown in this picture.
Pic of left bumper and a external magnet;
If it does then you have a lid magnet out of position. You will need go thru the process to disassemble the lid and check that the lid magnet is in position. First picture on page 35 of the SM shows the lid magnet.
You could have an issue with the left lid lock with corrosion and a possible open lead on the reed relay in the left lid lock. See the broken black wire connection as shown in this Pic
In the interim you could power down the machine by removing the 120VAC power cord from you wall receptacle then re-power up. That may give you three more wash cycles before the od alarm is triggered again. If the magnetic reed relay lead is open as shown this may cause a OP alarm to the console.
Post back if you have questions. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Jun 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Hi,i have a whistler 1773 laser-radar detector and it reads on the display DISTORT.i can't find anything in the owner's manual or on the website.can you help?thanks, angie
If compass is not calibrated correctly or if there is a strong magnetic field (dash or windshield mounted speakers), the unit will show incorrect direction or display "DISTORT". Re-calibrate the compass to correct the readings. Units that display "DISTORT" need to be moved farther away from the speakers or other magnetic field, then re-calibrate the compass. Optional Theft Protection/Extended Warranty Theft Protection
Whistler's optional 3 year theft warranty program (effective January 2002) offers the detector user protection against theft of their laser/radar detector. In the unfortunate event that your detector is stolen, it is comforting to know that your detector will be replaced! Simply follow the directions on the form enclosed with your unit or print out our online form and mail it, along with a copy of the receipt and payment, to the address listed. Once the form and payment is received we will provide you with a reference number. Note: The theft warranty protection isn't in effect until you receive a reference number from us. Our current program requires that the form and payment must be returned within 30 days of purchase, however and for a limited time only, we are waiving the 30 days from purchase requirement. If you have purchased any 1600 series laser/radar detector (This special offer is not available on any other detector model.) you are not too late, simply follow the instructions on the form and mail it in to us. In the unlikely event that your detector was stolen, simply inform us within 30 days of the theft and provide the following information:
  • Your theft protection reference number (Issued upon receipt of payment)
  • Name
  • Current complete address
  • Daytime telephone number
  • Email address (if applicable)
  • A copy of the police report indicating that your Whistler detector was stolen.
Once the above requirements are met a replacement or equivalent unit will be sent to you within 15 business days.
This offer is made available only to the original purchaser of the detector and is non transferable. Once used, this warranty is cancelled and a new one must be purchased for coverage of the replacement unit.
This offer is available in the U.S.A. only. Theft applications or claims from outside the U.S.A. will not be accepted and a copy of the original store receipt MUST accompany this form!
Extended Warranty
We are pleased to offer you an extended warranty for your Whistler laser/radar detector. Under the extended warranty, your detector will be warranted to the original purchaser for a period of 1 year from the date of expiration of the original warranty against all defects in materials and workmanship. To purchase the extended warranty, simply follow the directions on the form enclosed with your unit or print out our online form and mail it to the appropriate address provided, along with a copy of your sales receipt and a money order for $20.00, or payment can be made by Visa, MasterCard, American Express. (No personal checks will be accepted). You must receive a reference number (issued upon receipt of payment) from Whistler in order for your warranty to be in effect. This limited warranty is void if the unit is abused, modified, installed improperly, if the housing has been removed, or if the serial # is missing. There are no express warranties covering this product other than those set forth in this warranty. Whistler is not liable for damages arising from the use, misuse, or operation of this product. When returning a unit for service under warranty, please follow these instructions: Ship the unit in the original carton or in a suitable sturdy equivalent, fully insured, with return receipt requested, and shipping charges prepaid to:
The Whistler Group
Customer Repair Center
1201 N Dixieland Rd
Rogers, AR 72756
Include with your unit the following information, clearly printed:
  • Your name, street address, daytime telephone number and (if applicable) an email address.
  • A detailed description of the problem.
  • A copy of the sales receipt and extended warranty reference number.
To validate that your unit is within the warranty period, make sure you keep a copy of the original store receipt and the extended warranty reference number issued by Whistler. IMPORTANT: Whistler will not assume responsibility for loss or damage incurred in shipping. Therefore, please ship your unit insured with return receipt requested. -->
Feb 18, 2008 | Computers & Internet
Sigma Sport BC1106 Dts Wireless Bike Computer Logo
201 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
