Question about HP LaserJet 2100 Printer
WINDOW 7 IS NOT INSTALLING THE PRINTER HP2100. I ALSO INSTALLED EVERY KIND OF DRIVERS FROM HP WEBSITE BUT IT DOES'T WORK. TELL ME WHAT CAN I DO TO MAKE IT WORK?
  • 10,421 Answers
Previous use window xp recently have one note book window 7 our printer is not working window 7 processing the method of driver installed
My dear friend, observe computer peripherals compatibility. If you are telling that your printer is working on windows xp that means the printer designed only for windows xp but some printer right now is supported with different operating system. Anyway download a printer driver for windows 7 if it has and install the software first and plug the printer after installing the software. Have a nice day!
May 30, 2011 | Computers & Internet
Just got a new HP Pavilion desktop. HP support tells me my 7210 all-in-one is not longer supported and cannot be installed to work with the new desktop. Printer is 5 years old but works perfectly. Do I...
Sorry to inform you, but it appears that the printer is not compatible with Windows 7, which i think is installed in your new computer. I have checked the HP's website and they have not listed any drivers for Window 7 for this printer.
It does not mean that, we can't try to install it in this computer. Windows 7 has a very good feature called Troubleshoot Compatibility mode, in which we can try to install those drivers in the computer which are compatible with the older version of the Windows.
Mar 01, 2011 | HP Officejet 7210 All-In-One InkJet...
Scanner on my HP Photosmart 3310 not working and now need to reload the complete software. I have windows 7 64 bit
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://social.technet.microsoft.com/Forums/en-US/itprovistaprinting/thread/f9c40046-0de0-42d8-bb3c-4b56f8e404d6
Nov 15, 2010 | HP Photosmart 3310 Printer
Hp 2600n windows 7 network drivers
Click Here for the Drivers you'll need for this hp 2600n
hope this helps out, if so, please mark FIXYA!!
Nov 06, 2010 | HP Color LaserJet 2600n Printer
Cannot install Selphy CP400 onto a Windows 7 (64 bit)machine.
download vista 64bit drivers (cp400x64mux.exe). Extract these using winzip or winrar or 7zip. Rightclick CNYCPINS.EXE, click Properties, click Compatibility tab, and select Vista SP2 mode. Connect printer, rightclick CNYCPINS.EXE and click 'run as administrator'. Printer is now installed, works fine on my Win7 Home Premium 64bit.
Nov 02, 2010 | Canon Selphy CP400 Thermal Photo Printer
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
HP2100 aaargh!
Click on "control panel"
select "printers"
Do you see (hp2100) your printer?
If NO, it is NOT installed correctly.
If you DO see it, RIGHT click on it and select PROPERTIES
The GENERAL tab will show if it is working properly
Click on the Tab labeled DRIVER, and you will see an option to UPDATE DRIVER-click that.
Another way to view your printer is go to
CONTROL PANEL
then select SYSTEM then select HARDWARE
then select DEVICE MANAGER- (this will show everything-all your hardware and peripherals)
Look for IMAGING DEVICES and click on the "+"
Do you see your (hp2100) printer?
NO-not installed
YES-(but if there is a yellow triangle here it indicates an error)
RIGHT click on printer, select PROPERTIES
select DRIVER, click on UPDATE DRIVER.
You may need to restart.
Let me know how this works.
Hope this helps.
FYI : Xp does come with drivers, but they may be outdated, hence your problems.
Jan 14, 2010 | HP LaseJet 4350dtn Laser Printer
Driver for windows 7? I can not install my printer on windows 7. Can you give me correct driver for hp psc 1100 1200 series all in one?
Hello
Here is a link where you can download the driver for the spesific OS you are using.
Just click on the link below and you will be directed to the download page where you just need to choose the operating system and then download the driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=za&lang=en&product=90764&
Kind regards
Andrea
Dec 27, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 2100 Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
