Question about Sewing Machines
Pfaff 2144 I wish to take of side panel to unjam treads in tension discs I have used lace and a pipe cleaner no luck . Thanks Val Val.warren@ihug.co.nz
  • Val warren Oct 15, 2010
    This is a new way to to clear the tension discs to me thanks I passed it on to my friends at my sewing group today ,It fixed the problem
    Genius:
  • 1,456 Answers
Hello there
To clear threads jammed in the tension discs, Cut a piece of thread 1 1/2 yards long. Double it twice until you have four strands. Tie a knot in the middle. Use this hank of thread to clean both sides of the tension disks.
Wrap the ends of the thread around your forefingers. Hold your hands above and below the tension disk and pull the knot back into the thread slot. Pull the knot up and down through the tension disks to clean out any thread or lint between the disks. Repeat for the other side of the disks. Readjust your tension.
For best instructions for removing various parts of your sewing machine,consult your instruction manual
Posted on Oct 14, 2010
ChaMy pfaff 2144 will not stitch properly; pools masses of bobbin thread; Changed thread, tensions, needle etc still wont sew, please advise as I am so desperate to fix this problem
bunching of thread under material is a needle tension problem
tighten it up
proper tension is when it requires a small amount of effort to pull the thread through the needle eye
Jul 28, 2016 | PfaFF Sewing Machines
Where can I get a free pfaff 2144 repair/service manual ?
Service manuals are very difficult to find as the public was not an intended recipient.
Here's one for purchase:
PFAFF Service Manuals
Jul 25, 2016 | PfaFF Sewing Machines
I have a Pfaff 7550 that has tension problems. The bobbin doesn't seem to be coming through and the top thread is all loose and loopy. I have tried everything I know and still it is not fixed....h
How are you threading the machine? Is it with the foot in the up position? If you "floss" your upper tension discs with some sturdy fairly rough fabrick like linen. The disc sometimes get clogged up with lint, thread, wax from the tread... and prevent them from providing proper tension.
good luck.
Oct 01, 2012 | Sewing Machines
Pfaff 2144 won't stitch right side of buttonhole or skips stitches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Jun 11, 2012 | Sewing Machines
My kenmore mini ultra is bunhching the tread by the bobbin
try changing the needle--normally flat side goes to the back of the machine
make sure the thread & needle are correct for the fabric being sewed
rethread machine top & bobbin
make sure top tension is adjusted according to fabric & thread
Apr 06, 2012 | PfaFF Quilt & Craft Pro 7530
How do you thread a pfaff 2144? what is the first step?
1st step is look in the manual....need a manual ??
http://www.tradebit.com/filedetail.php/93895420-pfaff-creative-2144-instruction-manual
Likely to be similar enough to the 2170 for you to get it11_15_2011_9_03_23_pm.jpg11_15_2011_9_03_48_pm.jpg11_15_2011_9_04_05_pm.jpg
Nov 15, 2011 | Sewing Machines
Pfaff 7570 Tension Problem
You are threading this with the pressure foot in the down postion. So the tension is not engaging. clean the tension by running a pipe cleaner up and down the tension where the thread goes. it may have a piece of thread or lint in it.
Feb 01, 2009 | PfaFF Creative 7570
PLEASE HELP!!! Pfaff creative 7570 tension problems
Check your bobbin tension also. Embroidery bobbin thread is finer than sewing thread and you may need to make adjustment on the bobbing case by turning the small screw slightly. The type of stabilizer can affect your embroidery. An excellent reference for machine embroidery is Embroidery Machine Essentials by Jeanine Twigg, available on Amazon.
May 19, 2008 | PfaFF Creative 7570
Thread bunches under the material
There ARE still parts for your 7570 - amazing how rumors can get around!
Could be any number of things - from something as simple as a thread caught somewhere in the upper/lower tensions to the tension assembly to timing to any number of other things? You may have already tried some of these - hope this helps:
  1. Try "flossing" your upper tension - this is nothing more than running a heavyweight thread (such as upholstery or 12 weight thread) through the threading paths. Grasp the thread at the beginning of the threading path and the end coming through the needle and "FLOSS" (back and forth - just like you do your teeth). This will usually pull through anything that is gently stuck.
  2. Pretty much the same thing for the bobbin thread - if you're comfortable doing so, loosen the tension screw on the side of the bobbin case to make sure there aren't any little bits of thread fuzz stuck under the tension plate on the side of the bobbin case.
  3. Also remove the needle plate to allow you to better see the upper part of the bobbin system - if there are any bits of thread, etc. stuck in there, you may be able to see them and pull out with tweezers (turn machine off before you do this so the tweezers don't accidentally come into contact with anything).
If this doesn't work, you'll need to have a sewing machine tech look at it (I would recommend a Pfaff-trained tech as they're going to be the most familiar with your machine). The 2140/2144/2170 use most of the same parts - even the new CV still uses some of the same parts.
Good Luck,
Kim
Apr 11, 2008 | PfaFF Creative 7570
Sewing Machines Logo
180 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
