Question about GPS
I have Lexus LS430, 2004 Model. When I replaced car battery before few months, the navigation system stopped working. it displays (please insert correct map disc.). I took it to a specialist and he did the following to resolve the problem and make it work and took him only few minutes. 1) removed the map DVD disc, 2) insterted another DVD - I don't know what it is this 3) re-inserted the same DVD in step-1 and it worked the above problem repeated again after replacing the battery last week. I don't want to take it again to the specialist and pay money for simple job. please assist. Yousif Aldoubi
SOURCE: garmin zumo 550 switching on and off
keep your finger in the right bottom corner when you start up the unit. it will show a warning if you want to reset! push on "YES". it will reboot the unit. (please note that you have to remove your little memory card).
Hope it works... it did mine! SU
Posted on Jun 10, 2008
SOURCE: Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Posted on Jul 09, 2008
SOURCE: I bought Uniden GNS8361 3.5
Buy yourself a external antenna to strengthen the signal also make sure you have the current updates for your GPS device.
Posted on Jun 06, 2009
rocknpunkdad
SOURCE: Magellan roadmate 1412 just stop working and
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
Posted on Oct 08, 2009
SOURCE: Updated my FineDrive 400 to Aug 2006 data and now maps are gone
strabbr.bin
Posted on Jul 25, 2010
Gps on my 2002 lexus rx300 wont work it sayes disk is inserted but have no disk to insert
Sounds like the battery has been pulled or was dead for a while. You need to purchase the disk for your navigation system to reboot it somehow it has been erased or just damaged program. Look on ebay and even your Lexus dealer.
Apr 06, 2012 | Cars & Trucks
Hi, I have a BMW 525D '06 My problem is that the navigator suddenly stop working - "Reading error. Please insert DVD" and I can not use the navigator. Often it occur after aprox one hour drive....
This SIB may apply to this issue:
SI B 65 24 07
Audio, Navigation, Monitors, Alarms, SRS August 2007
Technical Service
SUBJECT
CCC Navigation Map DVD not Detected
MODEL
E90, E91, E92, E93 (3 Series) with SA 609 (CCC Navigation)
E60, E61 (5 Series) with SA 609 (CCC Navigation)
E63, E64 (6 Series)
E70 (X5) with SA 609 (CCC Navigation)
Vehicles produced from 8/31/2006
SITUATION
When entering into the navigation system, the screen only displays "Please insert DVD", even though a DVD map is inserted in the drive.
CAUSE
Incorrect map DVD
CCC software or hardware error
PROCEDURE
On a customer complaint basis proceed as follows:
Always verify that the correct map DVD is used (identified by DVD-CCC). Try a known good map DVD and see if the problem is resolved.
Update the complete vehicle per SI B09 05 01 (Programming and Coding with Progman) Procedure B, using Progman 25.00.00 or higher.
If the fault is still present, replace the DVD drive. Refer to Repair Instructions RA 65 83 580
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
DVD drive
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Mar 07, 2011 | 2007 BMW M6 Convertible
Battery new in last few months. Light comes on tonight saying battery is not discharging but belt is not loose...? 76000 miles
Stop by a local Advance, Autozone, etc .. parts store and have them do a free charging system test. Sounds like alternator is getting tired/worn. Have them test your battery also - they'll do both for FREE
Feb 18, 2011 | 2005 Lexus ES330
My 2004 RX330 Navigation GPS DVD does not load
another thought is try disconnecting the battery for and hour or 2 and see if that resets it,your last resort may be (hate to say it ) dealer to look at it
Oct 24, 2009 | 2004 Lexus RX 330
My 2010 Lexus RX350 Navigation System is responding VERY SLOW!
If Lexus can't fix this there is nothing anyone here can do for it. Anything that can be done needs the proper scanning and reprogramming equipment only Lexus has. Being that the car is new when enough people complain about this they will come up with a fix, Their may be a recall on it in the future. But for now your going to have to live with it or trade the car in. I know you did'nt want to hear this but but if some yahoo directs you wrong it will cost you hundreds just to get the programming back to the way it is today. Some navigation systems if you disconnect the battery you will have to go to the dealer to get them to reprogram it. Use lots of caution when guessing. New cars are not made for the average back yard mechanic to touch.
Aug 10, 2009 | 2004 Lexus RX 330
Is 250 navigation system does not work. the screen
I have the exact same problem. I was told by Lexus that there is no repair and the entire unit would need to be replaced for $2400 !!!!
Has anyone found a fix or alternate solution yet?
Jul 12, 2009 | 2006 Lexus Is 250
Can't get the DVD player to wok in my 2006 Lexus GS300
Repair Procedure
1. Confirm the customer's complaint of DVD RSE system inoperative.
2. For vehicles with Lexus Navigation System, perform the following procedure to turn OFF the RSE Lock function:
A. Press the INFO button to display the "Information" screen on the navigation unit.
B. Press the "Screen Setting" touch button on the navigation display.
C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display.
D. Press the DVD switch on the RSE system, (If a DVD is NOT already in the player, insert one) and confirm screen is "ON" and the system will play DVD's.
3. For vehicles without Lexus Navigation System, perform the procedure to turn "OFF" the RSE Lock function.
A. Push the audio control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "Rear Lock" is shown on the screen.
B. Turn the audio control knob so the display says "OFF" next to "REAR LOCK".
C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one.) and confirm screen is "ON" and the system will play DVDs.
4. If the above procedure resolves the concern, explain the system operation to the customer. This procedure is described in the "Audio/Video" section of the vehicle owner's manual.let me know lf this helps.
Jun 14, 2009 | 2006 Lexus GS
2003 Accord. Navigation/radio/display system does not load.
I've reads post here suggesting disconnecting the battery for one hour. Couldn't hurt to try it.
Also try ejecting the Navi Disk, inspecting it for any damage, wait a few minutes and reinserting. The disk contains not only the navigation Database, but also part of the operating system.
DO NOT TRY INSERTING A OLDER NAVI DISK OR ONE FROM ANOTHER VEHICLE, THAT COULD DESTROY THE NAVI UNIT!!
If you need a new Honda Navi Disk, order it direct at https://www.hondanavi.com/Hondadvdsales/naviorder.php
Good Luck
May 05, 2009 | 2003 Honda Accord
Navigation
It was not replaced correctly, more info needed..
Jan 18, 2009 | 2004 Lexus GX 470
GPS Logo
141 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
