Question about Ricoh Aficio 1515MF All-In-One Laser Printer
My Ricoh Laser Printer is not working
I have a Ricoh Aficio 1515 PCL 5e
The Lase printer is not working for some reason
we can receive faxes use the photocopy but not the network lases printer
I will appreciate if you can help
Regards
Elsa
  • 2 more comments
  • greenlineahm Apr 16, 2009
    not printing
  • jknutson3813 May 11, 2010
    You will likely have to reinstall the printer and\or reconfigure the printer. You can download the driver from www.ricoh-usa.com and use the add a printer wizard to install it. You will need to make sure the machine has a valid ip address programmed and that it is on the network. Have you printed to it ever or is this a new setup?
  • quennie732 May 11, 2010
    Are you using an ethernet cable/ serial cable,and there is a printer button on the control panel right? Print has nothing to do with fax, or copy.
  • Anonymous May 11, 2010
    I assume you have checked the cable is properly connected?
    Have you made any network changes? For example installed a new router? This will change you IP settings and require the printer be set to match.
    Do you have any other network printers or devices? Are they working?
    Can you 'Ping' the printer?
  • 183 Answers
For to use the network printer first of all you should have a network connection port.
If you have one on your printer than you should install a driver on the computer from where you will print then connect the cable with network LAN cable which the one end is connected into the printer and the other into the network switch or router. After this is done go to start menu on you computer than go to printers and faxes and select the printer driver 1515 press the right click and click on properties then go to port and create a TCP/IP port similar to the computer ip address.
EXAMPLE:
if the address on the computer is 192.168.0.100
than put the address of the printer as follow
192.168.0.101
Please look at the paper sheet which is printed from the machine by her self when the machine is turned on for the first time in the day.
There should have a port name which can be 10001 or 9100 or 9101 or similar.
Enter that number in the TCP/IP port properties than go to the machine and press the [User tools/ Counter] key then go to system settings and than network settings and enter there the ip address which you had enter before on the driver in the computer.
Posted on Jul 16, 2009
  • 46 Answers
Check all network cables conecting to the machine. Then rebbot the machine. Make sure that the machine is "online" by pushing the [printer] button and then the online offline button which is located directly under the [printer] button. It looks like an arrow pointing to the right. By pushing this button you will see on the screen ready or offline.
Posted on Aug 28, 2009
    New Friend:
  • 10 Answers
You can download a driver in the ricoh website at www.ricoh.com.sg. under downloads,
the driver you are using is outdated most users is using pcl6
Posted on Jun 11, 2009
    New Friend:
  • 63 Answers
You need to set up the driver at the computer side. First enter an ip address in the machine then download the driver from www.ricoh-usa.com/ good luck
Posted on May 04, 2009
Clear memory
This page of the manual seems to discuss the problem:
http://www.manualslib.com/manual/314275/Ricoh-Aficio-1515.html?page=46
May 09, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
I need a Widnows 7 64bit Fax Driver for a Ricoh 1515mf network copier, is there a work around to get this to work
try this site www.nrgcss.com
your machine is rex rotary --Dsm415
check if there are any compatible drivers
Jan 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Cannot Print nor Scann with Aficio 1515 PCL
Press the [Printer] button and then the the button under it. It looks like an arrow pointing to the right. Look on the screen it will switch between offline and online/ready depending on the condition of the network.
Aug 21, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Needed to have machine reset and now I lost my scanner
Do a Google-search for "Ricoh Aficio 1515 Printer downloads".
Select and download and install the software-drivers for your printer.
Jul 22, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Mar 31, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Printer Ricoh Aficio 1515
delete drivers and reload, make sure you're using PCL 5 drivers.
Aug 14, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
802 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
