Question about Luminox Evo F 117 Nighthawk 6402 Watch
Bezel on my 6402 just spins and won't click in place. How can I fix it?
My Tag Heuer CE 1111 has a loose bezel. I used to click when turned clockwise. How do I fix it?
It sounds like the spring under the bezel is broken. Just bring your watch to your local jewelry store, and they will give it to the watchmaker, he can repair it in less than a week.
Jun 12, 2011 | Watches
I have no instructional manual for my watch. How does the fixed Bezel help me find the time of any noted place in the world.james.peck
Sorry, a fixed bezel is for looks only. A movable bezel will allow you to calculate how many hours ahead or behind a certain time zone you are (although this type of bezel is mostly used for scuba divers). If your bezel won't rotate, it's there to look pretty.
I hope this helps! Please rate me with thumbs up if this helped you.
May 05, 2011 | Watches
I bought a Versace DV One White Ceramic watch. The bezel cracked and the Versace service center wanted $500 to fix. I think this is outrageous because I purchased the watch in May 2010 and the bezel is...
Thanks for contacting FixYa.
I am sorry. The only place to get a Versace replacment is thru Versace.
My only other advice would be to do an internet search and look for a less expensive replacement of the watch itself.
I know thats not what you want to hear. Best regards.
Jewel
Aug 28, 2010 | Versace Watches
Needs cleaning new glass and leather strap model siekodiashock 17 jewel date watch egp reverse egp 6402 1990 4do2324
mcdevito75 here, Best Bet is to check out the Repair Service Directory right here at fixya. Bottom of the page click on Repair Service Directory then watches, and choose a watch repair service for your watch.
Aug 22, 2010 | Watches
How do you get the bezel off of a tag heuer 4000 automatic, I have 2. The bezel on one is stuck from wearing on very dusty construction jobs, the bezel on the other turns but without clicking. Is there...
Yes, there are special spring under the bezel, not the bearings. Bezels are stuck/not clicking because they are broke/worn out or very dirty. I would not advise to take off bezels, unless you have replacement springs and proper tools to fit the bezels back on watch. You can find bezel springs on Ebay, or visit your closest watch repair shop and ask them to order springs for you. Rate me, plz.
Mar 27, 2010 | Tag Heuer Watches
F-117 Nighthawk 6402 series, moisture has entered watch face after swimming in pool on holiday.
This watch is resistant to 200m so shouldn't allow water in at swimming pool depths.
It looks as though one of the seals has failed.
If it still under warranty (less than 2 years old), then contact your nearest authorized dealer
To find your nearest dealer or their service center, go to Luminox.com. At the top of th epage you will see a list of links.
Feb 23, 2010 | Luminox Evo F 117 Nighthawk 6402 Watch
The outer dial free spins instead of clicks what is wrong with it
I think you are referring to the bezel around the crystal (glass). There is a spring under the bezel and it has broken. It can be replaced.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Fossil Metal Chronograph Blue Dial...
How to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
Sep 18, 2009 | Watches
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Citizen watch bezel does not stay in place.
If you've been trying to snap on that bezel and it does not stay in place, you probably lost the bezel fixing spring.
Find your nearest watchmaker and ask to sort things out.
Dec 17, 2008 | Watches
Luminox Evo F 117 Nighthawk 6402 Watch Logo
24 people viewed this question
Top Luminox Watches Experts
Dennis Fitzsimmons
Level 1 Expert
ibewjm
Are you a Luminox Watch Expert? Answer questions, earn points and help others
