Question about Haier Washing Machines
Hello We have an err 8 beeping signal ,our model is HWM1270KFL . Drum does not spin . Thanks
  • 2,382 Answers
Hi, according the the Haier Washing Machine user manual, Err 8 means "Water exceeds protective level" and you have to contact the maintenance personnel to fix it. Further usage of the machine may damage other parts.
The drum not spinning is also as a result of the Er 8 and unbalance laundry..
You can check out the error meaning on the page 18 of the user manual HERE
Posted on Oct 14, 2010
E000000-0000 err soluction
Dear
The error in service model pressing [* 28 *],(where press 2 & 8 together)(*- additional function)
(COPIER>FUNCTION>CLEAR>ERR).
Thanks.
Feb 03, 2015 | Canon Ir 3300 Black & White Copier
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
I have a Kenmore Catalyst washing machine, model #110.20056 992, that is triple beeping and only allowing one wash cycle type. Is there something I can fix on this?
Jun 19, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore elite washer cycle signal keeps going off an on turing cy
Jan 04, 2009 | Kenmore Washing Machines
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
170 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
