Question about Panasonic Microwave Ovens
Panasonic Microwave model NN-L526BA Works great most of the time, generally when I need to warm up my coffee or my dinner the only button that responds on the number pad is the reset button (it beeps when you touch it) the rest of the buttons are dead. After awhile it will start working again just as great as before, then it seizes again usually two or three times a day I get so annoyed that I wanna hit it with a baseball bat, so what gives??
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave -- Panasonic NN-S543BFR
I would say either the high voltage transformer or a component on the inverter board has failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 08, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
SOURCE: panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Posted on Jan 01, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
SOURCE: After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
Posted on Apr 06, 2009
How to make pizza in nn-s215mf
Problem with pizza in a MICROWAVE is the
mass of the pizza is not adequate to absorb the
radiation... Energy is returned to the ($50)
MAGNETRON significantly shortening the
LIFE-CYCLE of the OVEN.
If you must warm a slice of pizza or a pat of butter
you will be big $$$$ ahead adding a cup of water and
boiling water at the same time...
Have a cup of tea, broth or instant coffee too....
(big savings)
Repair manuals ($5)
http://www.panasonic.owner-manuals.com/NNS215MF-service-manual-PANASONIC.html
PANASONIC NN S215MF Service Manual
magnetron
https://www.amazon.com/s/ref=nb_sb_noss/158-8787537-8510360?url=search-alias%3Daps&field-keywords=nn-s215mf+magnetron&rh=i%3Aaps%2Ck%3Ann-s215mf+magnetron
Microwave pizza recipe
10 Best Microwave Pizza Recipes
Carnac the Magnificent
Mar 25, 2017 | Panasonic Microwave Ovens
How doi re progam my Panasonic counter top from demo mode to ther mode to progam and heat and warm up timed dinner plate and heattimed hot meal or beverage give ne insructions of what to do
A common answer to this for Panasonic microwaves is "4 presses of the Timer On/Off button" toggles Demo on and off.
Without you specific model, I can't be more specific than that.
Dec 25, 2014 | Panasonic Microwave Ovens
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Panasonic microwave ovens touch pad is not functioning in winters. But works well on a warm day. Do I need to clean out something specific?
That sounds like a condensation problem as when the microwave is cold the warm air from the kitchen that is laden with moisture is condensing and upsetting the control panel.
Keep it warm and dry? There is nothing specific though.
Feb 02, 2011 | Panasonic NN-T993SF Microwave Oven
My NN-T695 Panasonic microwave oven starts up for two seconds then cuts out before doing any warming?
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Mar 02, 2010 | Panasonic NN-T695SF Microwave Oven
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Re: Overheat Microwave or...?
Magnetron (supplies microwave radiation [energy]) or any of the high voltage components internally. More than likely, the HV (high voltage) diode has burned out and is probably cheaper to purchase a new one than have someone repair it unless they can do it for free or you simply pay for the part.
Sep 29, 2008 | Panasonic NN-S540 Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
