Question about Sony Ericsson K750
White stripes on display - Sony Ericsson K750
  • Sony Ericsson Master
  • 13,433 Answers
Hello, and thanks for using FixYa.
Most likely the screen is faulty, another problem could be that the cable is not connected properly to the phones mainboard. If problem remains with a new screen then the issue is most likely the connector or mainboard is faulty.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
If it helps, go ahead and click on the 4 thumbs and leave a short comment. As this is the free side of fixya, the comments are the only reward I can get for helping people like you who use the free services.
Posted on Oct 14, 2010
Testimonial: "Thank you, excellent, you are awesome."
  • Ekse Oct 16, 2010
    Let me know if you need further instructions on possibly taking apart the phone or where to obtain a replacement screen, if your outside of warranty.
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Hi, my motorola slvr l7 has felt on the floor. Since that it has one third (in vertical) of the display just full of thiny stripes (white and grey).. the rest of it still produce the different immages, but...
For fixing this problem you need to replace the LCD of your Moto. Buy the new LCD and get an T6 screwdriver, as for Nokia screws. This is not very difficulty to replace.
May 25, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
Wire order in new clip to replace broken end end 10 base T
From left to right:
1. White/Orange stripe
2. Orange/White stripe
3. White/Green stripe
4. Blue/White stripe
5. White/Blue stripe
6. Green/White stripe
7. White/Brown stripe
8. Brown/White stripe
Hope this helps!
Aug 07, 2010 | Unicom UTP Network coupler (ILC-S504C-SH)
Display problem
Hi, I had a similar problem and fixed it. Open the calculator and you will see that the ribbon connecting the LCD to the PCB has white and black stripes. The black stripes are the actual conductors. The white pieces are isolation between the conductors and serve the purpose of glueing the ribbon to the PCB.
Take a small flate screwdriver, its thickness has to be that of the white stripes. Heat up the end of the screwdriver with a hot air gun/lighter/hair blowdryer or whatever. Dont make it too hot. It should only be hot enough to melt the glue holding the ribbon to the PCB. Press the screwdriver on a white stripe and move the screwdriver up and down the white line which is on the PCB. Do this for each white stripe individually. Reheat the screwdirver if necessary, since there are a lot of tracks/stripes to cover.
It may be useful to use two screwdrivers: one to heat the glue of a white section and a second to cool/set the glue so that the ribbon is held in place, instead of coming loose because the glue is too hot. I did it only with one mildly hot screwdriver. It shouldn't be so hot that it actually burns you. You can test the temperature by pressing it against a hot melt glue stick (those used in a glue gun), if it melts the glue (but not too quick) it is hot enough.
It is unlikely that the ribbon came loose from the LCD, but if the previous didn't work you can try doing it on the LCD aswell.
Jun 17, 2010 | Sharp EL-334AB Calculator
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Sony Ericsson K750 Logo
114 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
