Question about Toshiba Satellite M35X-S311 Notebook
A very small amount of soda was spilled on the keyboard and now a few key on the left side of the keyboard feel like they are a little sticky (they don't pop back up like all the other keys). How can I clean these keys. Is there a way to take apart the laptop without doing more damage to it? Any help would be appreciated.
  • Toshiba Master
  • 13,433 Answers
Hello, and thanks for using FixYa.
Unfortunately the keyboard can not really be cleaned without a very high risc of ruing the whole keyboard. You have to replace the keyboard to a new one.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Posted on Oct 14, 2010
2 Suggested Answers
ryanb006
  • 48 Answers
SOURCE: spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Posted on Mar 23, 2009
How to take apart canon pixma 432. Spilled soda in it, need to clean inside.
Hi Daniel,
Let me say, up front, that I am not a printer guru. My background is in biomedical electronics, but this procedure works in most applications. Take distilled water and pour a small amount into the area where the soda was spilled. Wait a few minutes to allow the water to dissolve the dried soda. Then pour in more distilled water to flush out the residual soda. Allow to dry. The water should rinse out the soda, and when it dries it will leave no contaminates of its own. This procedure works well on medical devices such as telemetry transmitters and cell phones that have been spilled on. I hope this helps. Thanks for asking Fixya. Dan
Dec 04, 2014 | Office Equipment & Supplies
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
Aug 26, 2014 | Apple MacBook Air
Four keys in Belkin wireless keyboard are not working
If only specific keys are not working, something is obstructing those keys\' pickups which are located immediately beneath the keys. This is almost always caused by food debris or liquid spillage as dust doesn\'t provide particles big enough to cause issues.
If those four keys feel "funny" when being pressed, it\'s almost certainly a physical obstruction. If they feel "sticky" it\'s always a liquid spill. If you don\'t recall spilling anything over the keyboard, use a can of compressed air (found at office supply stores).
Turn the keyboard long side up, with the keys leaning slightly downward. Place the air nozzle close to the intersections of the keyboard, starting at one side and work your way to the other side, using short bursts of air. Repeat for every row of keys. Pay special attention to the four that do not currently work.
You\'ll probably see lots of junk fall out of the keyboard. That\'s good, if so--I would then retest the keyboard (no need to reboot the computer). That should fix it--if not, you may have to resort to pulling off the keys that don\'t work. The next possibility would be broken key hinges, but that\'s beyond the scope of this reply.
For liquids, cleaning is hit or miss. If left long enough, liquids will eat away at the circuits, or provide a short circuit and kill the component. Since only four keys are affected, I\'m really leaning towards food debris, but if you did spill a liquid, you can disassemble the keyboard and clean up any residue under and around the keys. Probably best to use rubbing alcohol and a q-tip for that--but if you\'re not comfortable taking stuff like this apart, it might be time for a new keyboard, or find a handy friend. Good luck!
Apr 07, 2014 | Belkin Wireless Keyboard/Optical Mouse...
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Spilled soda on my camera sticky lens
Buy lens cleaner, to wipe off what you can, but in truth the lens should be dis-mantled to clean it properly not to mention the rest of the camera.
Mar 29, 2012 | Sony Cyber-Shot DSC-H70 Digital Camera
Spilt coffee over keyboard
It might be :-( and usually stuff that lack isn't covered unless you pay extra for a high end warranty.
There are a few things you can do to try to save it though. As long as nothing shorted out (you didn't smell anything burning did you?), chances are a good cleaning could fix it. Are the keys sticking? Most laptops nowadays have a small try under the keyboard to keep stuff away from the vital electronics in case of situation such as yours.
1) Power down the laptop and remove the battery
2) Gently pop the keys around where the spill occurred, just pry them with your finger nail, they should snap right off with a little encouragement
3) Take a damp rag and blot up any remaining spills, or sticky spots, remember liquids and electronics dont mix so go easy on the water.
4) With a dry rag, blot up any remaining wet spots, can hurt to let it sit and air dry for a few minutes as well.
5) Pop all the keys back on and hopefully you'll be all set!
Feb 04, 2010 | Apple MacBook Mac Notebook
I spilled soda on my keyboard, and now the keys are sticky. How should I go about cleaning it?
u can get a can of IPA cleaning fluid from your local hardware store or use vodca or a nother alchole. unplug the keyboard first. :)
Dec 01, 2009 | HP Compaq 1701 17" LCD Monitor
Spill soda on my laptop keyboard
Mar 23, 2009 | Toshiba Satellite L305D-S5895 Notebook
Toshiba Satellite M35X-S311 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
