Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
3 concept II fans and 3 minka aire remotes wit 3 recievers in a 3 bedroom house all within 40 feet of eachother and remotes keep interfearing with eachother and there are no dip switches on reciever only remotes have dips how do i make each fan work independatly with its coresponding remote?
  • 377 Answers
According to the URL at: http://minkagroup.net/Admin/UploadFiles/F518-English.pdf there are dip switches on the fan. They are on the receiver that is most likely tucked away in the bell housing at the ceiling level. Pull the bell housing down and you will find a box of sorts that has the switches on it. This is the receiver.
If this solution is helpful to you, I would appreciate a Thumbs Up rating. Thank you, Paul
Posted on Oct 14, 2010
  • jeffrey vargo Nov 18, 2012
    well if that doesn't work, the label on the reciever tells you how. plus when pulling the 4 srcews(pull two the other 2 loosen rotate the base and it will come down) then hang the fan on the hook under the base so you don't have to hold it. Before all this.try turning on the power and with in one minute push fan off /on button on remote, then release and push and hold it down till the light flashes. this will make them chat to each other for commands
    Problem Solver:
  • 10 Answers
You willl find the dip switches....in the base of the unit...under the tape....the label hides them...so pull the base down and hang it on the hook the proceed to change the dip swithes. then when all is done. you need to communicate between the two of them. turn on the power. and press the on off button..then hold the on/off button down till you see the light flash on the fan.got to do this all within one minute.
Posted on Dec 01, 2012
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Can I use an incandescent bulb in a MInka Aire Concept II with light & remote? What is the highest wattage I can use?
Take the bulb to a bulb store & show it to them. They should be able to find a different bulb you can use.
Feb 26, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
No light or fan minka concept ii ceiling fan
You need a new receiver or tyr resitting the one you have and see if that works.
Mar 24, 2013 | Minka Concept II Flush 44 Ceiling Fan by...
2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Jun 24, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire concept II flushmount
try buying a wall mount remote. it must be made to be able to be programed
Jun 13, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Concept II
Depending on what year the fan was made try looking very close at the actual body of the fan. you may find a small switch you can manually use to reverse the direction of the blades.. I may have some used working remotes that will work with your fan if you like please feel free to contact me at payitforwardx2 @ gmail . com .
Jun 08, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
593 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
