Question about GPS
Where can I get operator instructions for an fm transmitter, Vector Imobile model vec430?
    Problem Solver:
  • 8 Answers
It is NOT a gps device it is a plug-in fm transmitter for players
Posted on May 31, 2014
Weather radio manual
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC438.pdf
Aug 30, 2013 | Audio Players & Recorders
Lost the instructions to my Maxell Digital FM transmitter for ipod. Are they somewhere online?
try this link and scroll down to m and see if your model is here. they did have a few.
http://www.fmtransmitterreview.com/fm-transmitter-manual.html
Sep 25, 2009 | Maxell Electronics - Others
Vector VEC438 AM/FM/Weather Radio my AC adapter
I have one of these too. Here is the information, in case you don't still have the adapter.
Ktec
Model KA12D090050034U
Input 120V AC 60Hz 95mA
Output 9V DC 500 mA
The inner part of the plug is the positive side.
Try googling the model number above. I did and found several sources. If you still have the adapter and only the power supply itself is bad (but the plug is still good), you may be able to splice on another 9 volt DC adapter, as long as the power output is 500 mA or greater. If you go this route, make sure to check the polarity before plugging it into the radio.
May 06, 2009 | Vector VEC438 AM/FM/Weather Radio
I need operating instructions for tunebase fm model NoF8Z049eaBLK
Go to www.belkin.com and click on support center and then type in F8Z049 and it will let you download the manual.
Jan 13, 2009 | Belkin TuneBase FM (F8Z049-BLK) Car...
Need user manual for Vector 127C Super Spot Light Can't figure out how to change the battery Need to buy a new battery also
Here's the manual link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC438.pdf
Dec 02, 2008 | Vector VEC438 AM/FM/Weather Radio
Technika fm in car transmitter
Tune in the transmitter to one of your car wireless stations - switch on - play MP3 player and it should work
Hope it works
Tony
Jul 11, 2008 | Pyle iPod Car Stereo FM Transmitter w/LCD...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Stormtracker
Here is the manual..from some obscure Black & Decker/DeWalt (the new owner of Vector) site:
-Jason
May 10, 2008 | Vector VEC438 AM/FM/Weather Radio
GPS Logo
46 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
