Question about Lexmark X5650 All-in-One InkJet Printer
How do i can print fax in memory , lexmark x5650
  • LXK Chris
    LXK Chris Oct 14, 2010
    Usually, the fax goes in to the printer's memory if the receiving transmission got interrupted by an error or a notification, i.e. low-ink level. You can still retrieve the fax, only if you replace the cartridge(s) (without turning off the printer or going to another mode, e.g. copy or scan). The printer will then try to continue where you left off with the fax. Contact Lexmark technical support for assistance.
SOURCE: lexmark x5470 wont print fax in memory
resent fax
Posted on Feb 06, 2009
atienzajude
  • 58 Answers
SOURCE: Lexmark X5650 cant scan
TRY TO REINSTALL THE SOFTWARE AND A DRIVER FOR THAT MODEL DRIVER
Posted on Aug 06, 2009
SOURCE: Print faxes in memory on a Lexmark X5470 All-in-One
I solved my problem by powering off, which I knew would lose the faxes in memory. However, I decided to have the faxes re-sent. As soon as I get time, I will address this issue with Lexmark. It seems incomprehensible to me that Lexmark does not provide instructions on how to do this.
Thank you for your interest. This simple question does not warrant a team to figure out--it is a manufacturer's responsibility.
Posted on Nov 11, 2008
ginko
  • 19396 Answers
SOURCE: i lost the Lexmark X5650 Printer, Scanner, Copier
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Mar 05, 2009
SOURCE: i havw a lexmark x5650, how do i get the fax to
my printer lexmark x5650 says the carrier is jammed how do i fix it
Posted on Apr 19, 2010
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 Fax Machine manual
Please visit the Lexmark website at http://bit.ly/ctQOTZ for the Lexmark X5650 Fax Guide.
I hope this information has been helpful.
Dec 19, 2011 | Lexmark Office Equipment & Supplies
Lexmark X5650 says faxes in memory. Already went to another mode. How do I get faxes out of memory?
Once you navigate away from the fax mode when a fax message goes into memory, you will lose the message. If this happens again, try not to navigate away from the fax mode. The "fax in memory" message usually pops up when the printer's not able to continue printing the fax due to a very low ink level. Just open the printer (w/o navigating away from the fax mode) > replace the ink cartridges > close the cover > print the fax.
May 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a Lexmark x5650 all in one unit. I can send fax but not receive fax. What do I need to do
Make sure the correct phone line is connected to the printer and the correct fax number is set in the printer. This article in the Lexmark website will help you identify and resolve your fax problem: Fax Troubleshooting Topics
Apr 16, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I have the 5600-6600 series need steps in printing from the memory ran out of ink
Whenever a fax is stored temporarily in the printer's memory due to low ink level, replace the cartridge right away. Without navigating away from the "fax sent to memory" message, hit Ok button. It will then print the fax. However, if you have navigated away from the message, unfortunately the fax will be lost and will not be printed anymore. You have to ask the sender to resend the fax. I hope this will help you in the future.
Mar 22, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
I havw a lexmark x5650, how do i get the fax to print out of the memory
Mar 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
Aug 06, 2009 | Lexmark X5650 All-in-One InkJet Printer
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
Lexmark X5650 All-in-One InkJet Printer Logo
1,247 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
