Question about Norelco 7610X Electric Shaver
I am having a hard time putting the triple heads back after I cleaned.
  • Norelco Master
  • 1,610 Answers
You will find a tutorial video at shaveroutlet.com. See link below and scroll down
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
Posted on Oct 15, 2010
4.0 jeep still back fire afther changing timing chain
I don't mean to question your skills, but have you double-checked your plug wires, that they're going to from the distributor to the correct plugs? (If you have a distributor!)
I have worked on cars for over 40 years, and recently changed the cap, rotor, plugs and wires on my V6, and it backfired badly when I was done. Only on the third (triple check) did I figure out I had put the wires in based on counter-clockwise rotation, when in fact the distributor rotates clockwise. But many other items got inspected and checked on my engine, including a full cleaning of the throttle body, while I tried to figure it out.
Nov 07, 2016 | Jeep Cars & Trucks
When removing the top triple clamp from a93 Zzr 600 e1 how do I remove the blind bolts from the bottom of the ignition barel ? Where the wiring is located ?
They are shear bolts...the heads are designed to snap off when first fitted to make it hard to remove them for security reasons . Usual method of removal is to drill them out and replace them with cap heads.
Nov 21, 2015 | kawasaki ZZR 600 Motorcycles
1986 - goldwing triple tree
dont they have bolts on the lower clamps also ?? if you loosened all and spread slightly each section then spray easing oil around clamps , get a hard rubber mallet and hit tops of fork tubes ! get a mate to put rubber gloves on and twist fork tube at same time ! support the weight of bike some how , rope round the head stock up to a beam !
Feb 01, 2014 | 1986 Honda GL 1200 Interstate Gold Wing
88 bmw m5 will not start after cylinder head replacement, backfires through intake any ideas???
any time an engine that was taken apart and put back together backfires, the first thing to do is double or triple-check the timing.
Feb 16, 2013 | 1988 BMW M5
CAN'T GET THE HEAD OFF OF THE BLOCK
Some times the head needs a little help. Be triple sure the head bolts are out and if they are: take an iron bar - put it in an exhaust port hole and lift it there. Might even take two men. This will usually do it. If this doesn't budge the head you do NOT have all the bolts out.
Jan 15, 2012 | 2000 Daewoo Nubira
I have an Iomega UltraMax 1TB Triple Interface External Hard Drive and have been told that the case/enclosure is dead, but that the hard discs inside are fine. Would it be easy to put them in a new case?...
It depends on the physical size of the drive.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=92&name=External-Enclosures
On the left there is a size filter. Pick one of those that suits your use.
Mar 21, 2011 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Change fork seals on 98 fxdl
You'll have to take each fork leg out of the front end to change the seals. I'm not positive what type front end is on FXDL but it it's a standard type (as opposed to an inverted front end), it's not too difficult.
First remove any sheet metal that might be covering the upper and lower triple trees. Lift the bike off the ground and remove the front fender and front wheel. Loosen the pinch bolt on the upper and lower triple trees. Do one tube at the time. Lubricate the portion of the top tube that is between the upper and lower triple tree. You must slide the fork assembly out of the triple trees. Loosen but don't remove the top caps.
With the fork assembly now out of the triple trees, remove the top cap and pull the spring out. Notice if the spring has a tapered end. Remember which way it came out so you can put it back in the same way. Invert the tube and pour out the oil and let it drain.
You'll see an 8mm bolt in the bottom. Sometimes this is a shallow piloted bolt. If so, you'll need at least a brand new hex key or allen wrench to loosen the bolt. Take the bolt out and slide the lower slider off the top tube. You now have access to the seal. Make sure you put the seal in faceing the correct way. Rince the slider out on the inside with clean mineral spirits and allow to dry. When you assemble the tube and install it on the bike, the amount of oil you put in it is the "dry" amount since you disassembled the tube and poured all the oil out. Put the sping back in the tube and install the top cap. Insert the tube into the triple trees and slide the tube upwards until the top of the top cap is 0.420" to 0.500" above the top of the upper triple tree (notice the height of the other tube that you haven't moved yet).
Good Luck
steve
Aug 17, 2010 | Harley Davidson FXDL - FXDLI Dyna Low...
04 crf 250r.... the head has a chattering noise when running
Any chance the valve spring has collapsed? Cam shaft thrust washers missing? Cam shaft bearing gone bad?
abe5193.gif b3c3550.gif Please rate this solution. Thanks!
Jun 22, 2009 | 2005 Honda CRF 250 R
What would cause my1999 Saturn sl1 not to start after a new head gasket was put on? Ok so today we replaced the head gasket on my 1999 Saturn Sl1 single cam. We made sure the timing chain was put back on...
Check the cam/crank sensors. Also, if the car happens to have a distributor, make sure it is not 180 degrees off. If this does not help, then do a compression check. Remember, and engine only needs three things to run. Fuel, Spark, and Compression. (in order of course.) The firing order for your engine is 1,4,3,2.
Mar 23, 2009 | 1998 Saturn SL
Norelco 7610X Electric Shaver Logo
52 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
