Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
Hi, I have a Hotpoint top freezer and refer MD# CTX22DKG and I have know idea how old it is. The freezer works good but the refergerator stoped working. Is it worth fixing or do you have any advice what is going on.
    President:
  • 1,891 Answers
Top freezer hotpoint style have a fan in the freezer behind the back plate and if it isn't working then it will not blow the cold down . other it might have iced over the air duct caused by the drain in bottom of freezer being plugger . . so when you open the freezer door you should hear the fan . and if you see ice in the bottom -back side its a drain problem . hope this helps mm
Posted on Oct 14, 2010
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
HI-- I have just purchased an old Olympus Trip MD 35mm automatic camera, with in built flash. I think have correctly loaded the fillm and batteries, but it won't turn on...It won't take pictures...
Make sure that the batteries are good. If it does not work with known good batteries then you certainly have an issue with the camera electronics. Test to see if the on/off switch is any good.
Aug 22, 2017 | Hi-Capacity Cameras
Refergerator not coolinng but freezer working good on a side by side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Kenmore Refrigerators
Our hotpoint fridge freezer ffm74 has stoped working. The freezer doesnt work and the fridge is freezing everything.
hi the fridge requires cold air from the freezer,the air cant get in there due to ice blockage,defrost appliance for min 36hrs and then once the appliance reaches approx -12o the fridge should start to go cold
Aug 03, 2009 | Refrigerators
FREEZER WORKS BUT REFRIGERATOR SIDE IS WARM
check if fan that blows air to the refridge is working or vent clogged
Jul 24, 2009 | Magic Chef CTB1821AR Top Freezer...
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
134 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
