Question about Car Audio & Video
Jensen VM9414 parking brake bypass using the codes listed in 2008 post of 1, 2, 6, 4 code has not worked. Is it possible that my new unit (July 2010) has had a code change or other lock change to prevent bypass?? Louis
  • Louis DiFrancesco Oct 21, 2010
    Jensen VM9414 parking brake bypass, if the above solution does NOT work, and I know that grounding the wire did not make any difference then there is no solution for this particular model with these particular features: SO what model that has these features can be successfully bypassed??
    I am planning to buy a second radio/TV/nav/bluetooth/usbport/SDmemorycard for my other transport. What model at this great price point for a person that does not notice the improved sound quality of the Alpine, etc brands (had both a Blaupunk and an Alpine model and did not notice any difference other than the manufacturing quality of no broken solder joints)
    The features are the most important thing to me. I listen to audio-books while I drive for the most part and not the radio because of poor reception for the stations that I like because of the distances that I travel.
    Louis
  • 2,382 Answers
Hi, here is another trick to the parking brake bypass procedure:
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6. Use the unit wisely and above all safely.
Secondly, you can try grounding the wire and that does not also work, then am afraid that the 2010 unit has other lock change to prevent the bypass.....
Posted on Oct 14, 2010
How do i bypass the parking brake on my jensen vm8013hd
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
Dec 28, 2009 | Jensen Car Audio & Video
What would be the best way to bypass the E-Brake on a Jensen VM92
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jul 02, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
i did not make this lil tutorial as i found it on the ecoustics forum at http://forum.ecoustics.com/bbs/messages/4/278797.html i do not take credit for this tutorial. i found it very helpful.
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit. fullsizechevysig.jpg
May 15, 2008 | Car Audio & Video
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Brake bypass
Insert the DVD
Region Code
Loader Version
Model Version
Region Code: 1
Brake Override ON
Macrovision: OFF
Best of Luck!
Nov 26, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9412 Video BYpass
The solution that was givin for vm9412.
going to SET UP
Then Language.
Then on your remote push 543210.
Press the Hammer & Screwdriver symbol.
Click on praking brake overide and turn it on.
Then hit the X at the bottom of the screen.
And say good bye to the pink wire bs & ground.
This solution was awsome it only took one try very easy!
I Give total props to FixYa.
TTTHHHAANNKK UUUUUUUUUUU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 30, 2007 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
1,289 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
