Question about Jandy Ae2500t 115,000 Btu Heat Pump
Display fault shorted H2O sensor, what s the problem solver
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Replace temp sensor it is shorted
Posted on Nov 12, 2014
1998 dodge ram 1500 po132 engine light wont go off after replacing h2o sensors
the h2o sensor may not be the only problem, some thing else is setting off the sensor, a pin hole in the hose, a loose connection, cracked lines, plug lines, blockage of sensor that controls the h2o unit, look at the whole picture, housing, gasket is that area, too much h2o, not enough h2o, gases mixtures + h20's, make sure you have the air pressures sucking and pushing through the line.
you are going to have to a service manual and general information how the h20 system works in that vehicle. test points.
www.ask.com/year/mfg.name/make/model/how/does/H20/system/works/on/vehicle/
Sep 18, 2015 | 1998 Dodge Ram
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
Ae3000t
shorted temp sensor replace
Jun 22, 2014 | Jandy Ae2500t 115,000 Btu Heat Pump
Faulted h2o sensor
replace temp sensor
Aug 04, 2012 | Zodiac Pool & Spa
I have a hotpoint Ultima WT741, and it doesnt stop filling up whilst in use on a wash/spin and says H2O, and then overflows out the top of the washing machine. Whats the matter with it?
If the flow at the inlet valve is good and then the water comes into the system. Now if the WATER LEVEL SENSOR - normally a pressure switch- does not activate at the preset/chosen level to give the signal to the program controller to switch off the INLET VALVE , it will overflow. So the fault is the water level sensor and showing the error H2O.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 22, 2011 | Washing Machines
Shortd H2O sensor, Fault
replace temp sensor on heater should be by plumbing inlet
Dec 08, 2010 | Jandy Ae2000t 100,000 Btu Heat Pump
What is blink code 22 for a 1992 tercel
Code 22 is the Water Temperature Circuit Open or Shorted.
Fig. 1: Trouble codes for 3E engines
Fig. 2: Trouble codes for 3E-E engines 85994112.gif
Fig. 3: Trouble codes for 3E-E engines 8599412a.gif
Nov 07, 2010 | 1992 Toyota Tercel
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Fault shorted H2O sensor??
the sensor goesw into the header unscrews with two black wires
May 02, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
Feb 24, 2009 | 1993 Saturn SC1
Jandy Ae2500t 115,000 Btu Heat Pump Logo
184 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
