Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Every time i turn on the tv it makes the click noise it is suppose to and the little red power indicater bulb flashes for about 5 to 7 secs like always but right about the time the screen usually kicks on it turns itself off...or the screen doesn't turn on im not sure which.
    Top Expert:
  • Sony Master
  • 74,251 Answers
Please check the horizontal output transistor for leak, base-emitter. Change it.If there is any kind of short in the board, the power supply will sense int and will shuts down. Line out put transformer [LOT] may also suspect. On the secondary supply stage from LOT, the secondary power supply section, check all the rectifier diodes, and its filter capacitors for leak. Even a slight leak will effect the proper function of the set. Check it with good qulaity analongue multimeter, with setting it to meg ohms range; check the suspected componets off board. Likewise check the primary rectified DC voltage at SMPS stage. It should be aroung 380V DC accross main filter capacitor. If it is not check the main filter capacitor [usually 330Mfd 450V] for low capacity. and check the four main rectifier diodes.
Posted on Oct 14, 2010
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Tv turns off and on repeadly
if bulb is ok and this is a DLP the ballast that fires the bulb could be bad.
Dec 14, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
