Question about Nikko STIRLING PLATINUM NIGHTEATER RIFLE SCOPE -- 1"Power: 6X36 / Reticle
Scope runs out of windage adjustment - Nikko STIRLING PLATINUM NIGHTEATER RIFLE SCOPE -- 1"Power: 6X36 / Reticle
  • Nikko Master
  • 2,113 Answers
Is the barrel bent
Posted on Mar 11, 2015
SOURCE: zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Posted on Jan 25, 2009
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
Adrian762
  • 425 Answers
SOURCE: I have lost the covers to my windage and elevation
From any reputable gun shop that stocks simmons scopes.
Posted on Feb 14, 2010
  • 115 Answers
SOURCE: I need the windage dial for my Bushnell 3-9x38
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Posted on Mar 24, 2010
  • 115 Answers
SOURCE: Windage fully clockwise "In" and not quite there at 100 yds.
remount the scope using millett angle lock rings that allow you to adjust for windage. bring the scope as close to hitting bulls eye as possible then use the scopes adjustments for the fine tuning. before remounting you will want to recenter the reticule.
Windage and elevation adjustment won't move on konus 275 scope
you may have run out of clicks or the adjustment internals are damaged
Nov 02, 2013 | Konuspro 275 Muzzleloading Riflescope...
Haveing problem with the windage adjust and elavation adjustment it is working backwards.
If your point of impact needs to move up, turn the knob the direction that says up. If it needs to move left, turn the windage knob the direction that says left.
Jan 21, 2011 | Optics
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Mar 14, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
CAN NOT ZERO GUN
You may try to bore sight it first. Pull the bolt and setting the gun on a good rest sight thru the barrel at a dot on the wall within ten feet. Then adjust the scope to that dot. As you adjust the scope tap the bore of the scope with a screw driver handle, tap it after each adjustment not hard, but enough to give it a sharp jolt. Once you are close here, move out to the range and shoot at 15 yards. Using a rest, again tap the scope after each adjustment. Then move out to 50 yards and you will want to be shooting high 1.5 to 2 inches here. Shoot slow keep the barrel cool and try for 2 shot groups till you have got the scope dialed in. Then move out to 100 yards for your preference of zero. Remember use the same ammo you will hunt with or at least the same bullet weight. If you can't get her to get on paper you can try to loosen the scope in the rings, one at the time once the gun is a little warm. Loosen the barrel ring first then snug it back down and then the receiver ring. If your group moved now, she was in a bind due to a cold gun at set up / installation.
Dec 01, 2009 | Optics
The reticle adjustment knob is turned all the way out (counter clockwise) and still hasn't moved the point of impact to the right enough.
If you have Leupold/redfield style windage adjustable baes you just need to move the windage adjustments. If you don't have these, I would recommend you take your rifle to a qualified gunsmith and have him remount and boresight your scope with this style scope base(s) which should run you about $80.00
hope this helps, Mark the Gunsmith
Oct 22, 2009 | Optics
Question about Swarovski Scopes
iv had this problem many times before,,,its more likley to be a bad set of mounts not inline with the barrel,,, if you have ran out of windage adjustment,, to get over it i use a strip of 35mm film inside the scope mount to push the scope over a bit,,, but a new set of mounts would be the best way forwards
Oct 13, 2009 | Swarovski Optik PH6-24x50 Weapon Sight
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Windage adjust correction
Go to; www.bsaoptics.com for the manual and parts.
You do not say if the WINDAGE Adjustment KNOB is 'broken' or what? If you have dropped it or somehow broken it, it's unlikely that you will be able to repair it yourself, in which case I refer you again to BSA.
If there's nothing wrong with the scope or your rifle, and you are simply having difficulty getting a good ZERO, I can help you with that, just respond and let me know.
Good luck. :)
Dec 09, 2008 | BSA Deerhunter Riflescopes Deerhntr 3-9x40...
Lost caps
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Oct 16, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Nikko STIRLING PLATINUM NIGHTEATER RIFLE SCOPE -- 1"Power: 6X36 / Reticle Logo
236 people viewed this question
Top Nikko Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Nikko Optic Expert? Answer questions, earn points and help others
