Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Jenn air french door refrigerator
My temperature reading for my refrirgerator is escalating from 57 yesterday  to 61 today .. what's going on with the gauge?
  • eliramos Jun 02, 2008
    you guys keep saying turbo cool .. what is that and how does one activate it .. I turned off the refrigerator .. the temperature jumped to 71...plug it back in .. pushed the down arrow in the refrigerator to 33 (that's the lowest temp it allowed me to go) and went to bed at 9:30 PM .. at 4:30 am the temp read 59 and seems to be rising again (6:30 am) .. the freezer is still at 0 .. help
  • nycjimster Dec 26, 2008
    Same problem...freezer working, but fresh food in the 60s. How did you fix your refrigerator?
Dear Sir or Madam:
Our refrigerator was purchased in 2006. The modle number is JFC2089HES. Recently the temperature in the top two shelfs become warm. the display shows 62 C. However, the hole in the rear back behind the drawer has cold air coming out. So the bottom shelf is cold. This situation has been two weeks already. Now I transfer most food to anther refrigerator. This refrigerator is almost empty. But it is still warm. I was wondering the cold air should go down and hot air should go up. So how the cold air coming out of bottom shelf go to top shelf. I can't find any opening in the top shelf. Can you please provide some advice for this problem. Thanks!
Huizhu Zhang
Posted on Nov 08, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
With the indulgence of XX,
Would appreciate an update on any development(s) or even the lack of it.
Good luck and thank you for using FixYa.
Posted on Jun 02, 2008
  • Louie  Role
    Louie Role Jun 02, 2008
    sorry worldvet, was templating again.
  • Louie  Role
    Hi again,
    In your particular model I believe it is termed as "MaxCool". It is also possible that the sensor for the refrigerator is covered by a food item and therefore was getting erroneous readings hence cutting off early (making the temp go higher than normal). Based on this, you can try switching the food items around relocating them as to how they were placed inside. Incidentally, frequent opening and closing of the refrigerator of course would be exposing the inside to warmer air making the unit work harder.
    The reset requires that the unit be unplug for an hour or more hence my suggestion during the Live Session to make use of a second refrigerator while checking out the Jenn Air.
    Guru:
  • 859 Answers
Can you place the unit into Turbo Cool? once it reaches 34 degrees it will reset to 40.
This can happen if you've recently added a lot of food lately, such as for a party. The energy saving nature of the unit cannot cope with the influx of a lot of food food from the grocery store all at once.
If that doesn't do it, stick around and someone will be along to help you.
Kind regards,
Worldvet
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn air refrigerator temp gauge problem
Hi again,
Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
227 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
