Does the hp print head have protective cover on the copper contacts?
  • 31 Answers
When brand new in package, yes it does. But you pull it off to install into the printer.
Posted on Oct 14, 2010
Not reconizing printer head
Have you cleaned the print head contacts? If not, try this- open the the front cover with the machine on, the printer cartridges will move to the left and stop-
Don't shut off machine- on the right side of the cartridges you will see a gray handel- holding the bottom of the handel pull it towards you {clock wise} till the lever is in the up position; this will release the print head, next lift the print head (hold the cartridges) up and pull out the assembly.
On the back of the print head you will see copper contacts- clean them with alcohol or other such chemical. Look in machine where the print head was and you will see more copper contacts- carefully wipe them with a contact cleaner.
Reinstall print head, lift gray lever to lock it in.
Close front cover.
Mar 22, 2013 | HP Officejet Pro 8600
Print cartridge is missing or not detected.
removed and uninstall the cartridge once more, or cleam with dry cloth the metallic surface on your ink, gently rub until you removed any dirt, if you cannot fix it chances are the cartridge is damage already and you need to buy a new one
Aug 11, 2008 | HP Office Equipment & Supplies
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
All my colour cartridges are ok.I've just replaced the black cartridge but its not printing anything black. Checked the openings there all clear...Checked the ports in the printer itself../.they're clear....
Run the clean print cartridges utility
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Solution Center , select the Settings menu, then the Print Settingssubmenu, and finally the Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and chooseProperties . Click Printing Preferences . Click the Features tab, then thePrinter Services button, then click the Estimated Ink Levels tab.
  2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Clean the contacts NOTE: The printer will only function if all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Figure 3: Lifting the top coverc00706023.gif
  1. Lift the top cover.
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch. Figure 4: Unlatching cartridgec00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 5: Removing cartridgec00372273.gif
  4. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab and squeeze out excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 6: Wiping the contactsc00372274.gif 1 - Copper contacts
  7. Replace the cartridge, then close the latch and the printer top cover.
Mar 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
My printer is asking me to check replace colour cartridge, i have done this but still the same issue and i obviously can't do anything with it. thanks
Issue After you install a print cartridge, the following message appears on the color graphics display: Cartridge error: one or both cartridges are not intended for use in this printer . The device will not print. Solution Step one: Remove, inspect, and reseat the cartridges The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridgec00484998.gif
  4. Slide the cartridge out and inspect it: CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tapec00211538.gif
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figure 4: Sliding the cartridge into the carriagec00484999.gif Figure 5: Pushing the cartridge into placec00485000.gif
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My HP Photosmart 2600 displays "remove and check cartridge on right". I know it still has ink. I removed it and replaced it and it is still displayed and won't print.
Step 1: Remove, inspect, and reseat the problem cartridge
The cartridge might not have full electrical contact with the product. Removing and reinstalling the cartridge might help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Use genuine HP cartridges to ensure good quality.
1.
Make sure that the product is turned on.
NOTE: Press the power button ( ) to turn on the product.
2.
Open the product cover and wait until the carriage is idle and silent.
3.
Open the cartridge latch.
1.
Press down lightly on top of the latch.
2.
Pull out the bottom of the latch to unhook it.
4.
Slide the cartridge out and inspect it.
Slide out the cartridge
Electrical contacts and ink nozzles
2 - Ink nozzles
1.
Check the copper electrical contacts for debris. If any debris is evident, proceed to "Step two: Clean the cartridge and carriage contacts."
2.
Make sure that the clear nozzle protective tape has been removed.
Figure 4: Remove the clear nozzle protective tape
Remove the clear protective tape
1 - The clear nozzle protective tape
CAUTION: Do not try to remove the copper electrical strip.
3.
Look at the number on the cartridge label and make sure it is compatible with the product. Compatible cartridges are listed in the product user guide.
5.
If the cartridge is not compatible, obtain the correct cartridge, and then go to "Step five: Replace the cartridge." If the cartridge is compatible, reinstall it in the product:
1.
Hold the cartridge with the nozzles down and the copper electrical contacts facing the product, and then slide the cartridge into the carriage.
Insert the cartridge into the correct slot
2.
Push down on the cartridge latch until it snaps closed.
Slide the cartridge into the slot
Close the cartridge latch
6.
Close the product cover.
Step 2: Clean the problem cartridge contacts
1.
Gather the following items to clean the cartridge and carriage:
2.
Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
Sheets of paper or a paper towel to rest the cartridge on during cleaning.
3.
4.
Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
5.
Unplug the product from the electrical outlet.
6.
Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
7.
Clean the cartridge contacts.
CAUTION: Do not touch the ink nozzles.
Cartridge contacts
8.
Clean the contacts in the carriage, inside the product.
Carriage contacts
9.
Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
10.
Reinstall the cartridge.
11.
Reconnect the product to the electrical outlet.
12.
Step 3: Repeat reseating and cleaning steps
If the problem is not solved, repeat the reseating and cleaning procedures above.
Step 4: Contact HP
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now. Click here (c00206040) (in English) to see if the cartridge is covered under warranty.
Step 5: Print in backup mode
If you do not have a replacement cartridge, you can still print in ink backup mode. Simply remove the problem cartridge, and print with the remaining cartridge.
If you remove the tri-color cartridge, printouts will be in grayscale.
If you remove the black or photo cartridge, the product prints slowly and the colors in the printouts might differ.
Jan 26, 2010 | Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
The printer tell me incert black printer cartidge in right stall. or photo cartidge. I've install the cartide but print does not reconized the installation.
HP Officejet 7200, 7300, and 7400 All-in-One Series - 'Incorrect Print Cartridge' or 'Insert Print Cartridge in...Stall' Message Displays on the All-in-One After Installing a Cartridge Issue After installing a cartridge, the error message Incorrect Print Cartridge or Insert [Black or Photo / Tri-color] print cartridge in [right / left] stall appears on the product control panel. Solution Follow these steps to resolve the issue. Step one: Remove, inspect, and reseat the cartridge The cartridge might not have full electrical contact with the product. Removing and reinstalling the cartridge might help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Use genuine HP cartridges to ensure good quality.
  1. Make sure that the product is turned on. NOTE: Press the power button (c00636182.gif ) to turn on the product.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Open the cartridge latch.
    1. Press down lightly on top of the latch.
    2. Pull out the bottom of the latch to unhook it.
  4. Slide the cartridge out and inspect it. Figure 1: Open the cartridge latch c00211535.gif Open the cartridge latch Figure 2: Slide out the cartridge c00211536.gif Slide out the cartridge CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Copper electrical contacts and ink nozzles c00211537.gif 1 - Copper electrical contacts 2 - Ink nozzles Electrical contacts and ink nozzles
    1. Check the copper electrical contacts for debris. If any debris is evident, proceed to "Step two: Clean the cartridge and carriage contacts."
    2. Make sure that the clear nozzle protective tape has been removed. Figure 4: Remove the clear nozzle protective tape c00211538.gif 1 - The clear nozzle protective tape Remove the clear protective tape CAUTION: Do not try to remove the copper electrical strip.
    3. Look at the number on the cartridge label and make sure it is compatible with the product. Compatible cartridges are listed in the product user guide.
  5. If the cartridge is not compatible, obtain the correct cartridge, and then go to "Step five: Replace the cartridge." If the cartridge is compatible, reinstall it in the product:
    1. Hold the cartridge with the nozzles down and the copper electrical contacts facing the product, and then slide the cartridge into the carriage.
      Figure 5: Insert the cartridge into the correct slot c00211539.jpg Insert the cartridge into the correct slot
    2. Push down on the cartridge latch until it snaps closed.
    Figure 6: Slide the cartridge c00211540.gif Slide the cartridge into the slot Figure 7: Close the latch c00211541.gif Close the cartridge latch
  6. Close the product cover.
If the issue continues, get back with me there is a few more options we can try. Have a good day
Jun 24, 2009 | HP Officejet 7210 All-In-One InkJet...
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
16 people viewed this question
jasbo
jasbo
