Question about Fisher and Paykel IWL12 Top Load Washer
Machine will fill with water,will not spin to wash just beeps
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine beeps an error code will appear.This will be in your LCD display or in a series of lights being lit.Now the lights that are lit when the machine is beeping will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 2nd and 5th or the 3rd and 7th ---etc---? Please reply reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 14, 2010
  • blue__bell01 Nov 01, 2010
    i have the same problem as the above question however the 8th light flashers (spin cycle) when i hold down advance, power and start light 6,7 and 8 all flash (6th= rinse) can you help me?
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Washer does not fill with water but motor continues to turns drum
Yes the drum will always spin when filling it is called stirring, however, you will find you need to replace the (I assume) cold inlet valve, or you could put the cold hose on the hot valve and do a hot wash, this means it would fill with cold water, however some machines do have a sensor for sensing water temp, if this is so the machine will beep, and it may take some time to fill. :)
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
When i put the wash cycle on it goes and does fill up with water, but then when comes to spin cycle it stops agitating and starts beeping constantly with the light on where the "lid locked" icon is.. When...
Hi Ellie,Just read your posting.Now does your machine drain most of the water from the machine but it does not spin the clothes dry?Is this correct?Also does the mahine only show the lid lock icon when the machine is beeping?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
564 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
