Question about Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White
Whirlpool 445L white Fridge Model: WRID41TW It started with dripping water into the fridge from top (freezer?). I was unable to locate the water source. Three days later, the freezer started frosting but the fridge stopped working. A week later, a whirlpool technician came to investigate the problem and he deemed it beyond repairing. Has anyone out there had the same experience? Is there a solution to it. I like my fridge and wish to make it work again.
  • 618 Answers
Have you tried it after letting it defrost for a couple of days . It sounds like it was just frozen up. If the freezer is still working then it is the defrost drain is frozen up.
Posted on Oct 14, 2010
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
After defrosting, the freezer will not start. - Whirlpool fridge.
I presume that you still have got electricity power and the fuse has not 'blown' - if not you could try putting in a new fuse in the plug, sometimes two problems can occur simultaneously.
Otherwise I would leave the door shut to keep the stuff as cold as possible, some may refreeze, or ask a neighbour, friend, or relative to let me have some space in their freezer.
Aug 28, 2012 | Whirlpool Refrigerators
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is dripping into refrigerator from opening on top (between the freezer & fridge located toward the back of the inside of the fridge). About the same amount of water daily. The problem continues...
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
Mar 20, 2009 | Refrigerators
Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Sep 11, 2008 | Whirlpool ET8WTKXK Top Freezer...
Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White Logo
444 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
