Question about Maxtor Shared Storage II (S01R320) Hard Drive
How can I connect and access NTFS formated hard drive?
  • 979 Answers
Hello sir, hi try installing your hard drive to another pc with XP vista or 7 the ntfs drive will be read.
Posted on Oct 14, 2010
  • 193 Answers
SOURCE: hard drive
mabe u have many partitions and they were set hidden or unactive...go controlle panel..administartive tools, device managment or somthing like that..i the diagnostik tools take the 3rd option frome the second 1...u will find ur hidden partitions u can set it active and reboot evry thing wiill be ok.......but if u dont see them u can dowlaod any live cd like nothon ghost or any partition live cd and boot frome it u will find the solution thre sure
Posted on Feb 13, 2008
cinek79
  • 320 Answers
SOURCE: Virus has converted hard drive to raw format, need info off it.
try in command promp: CONVERT [drive] /FS:NTFS
Posted on Aug 08, 2008
cisco167
  • 36 Answers
SOURCE: drive not appearing
You formatted, but did you create a Partition? Go back to Disk Management and create a Partition on the drive. You should be able to now see it in "My Computer."
Posted on Jul 02, 2009
  • 191 Answers
SOURCE: how can i change my 1 tb desktop hard drive from
to convert a drive from NTFS to FAT32 you need to use partition magic program
Posted on Sep 24, 2009
  • 383 Answers
SOURCE: Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
Posted on May 27, 2010
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
How can i make my WD passport fat 32 compatible
  • By default Windows Operating System follow NTFS Format and NTFS based File Managers support FAT32 format without any additional changes.
  • Fat32 is also accessible in Linux Operating System without any modification whatsoever
Apr 06, 2010 | Western Digital WD Passport 250GB Portable...
My computer does not recognize my simple drive when I plug it into computer
Please note that: a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, then it means that you have some hidden partitions on your external drive, so when you plug it, try and do this:
Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Also Make sure that the USB port that you are using is a USB 2.0 port, and not USB 1.0 port, you can just try the other ports there, to be sure.
Hope this helps you out.
Nov 17, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
I have an iomega exteranl hardrive whic i can access on my Mac laptop, but when i connect the drive to my my windows based laptop, it's not accessable
I not a big mac expert but it is probably to do with the way your portable drive is formatted. Windows pc's will recognize drives formatted as FAT32 or NTFS. Mac's will also recognize these formats. If the disk was originally formatted with a mac format like HFS is won't be recognisable to windows. Connect it to your mack and look for the Fike System Type. You could back up any files you have on the portabe device to your mac hard drive then format the drive on a windows machine. Start with a NTFS partition and see if your mac can read and write files to it. If not then try again with fa32. Once you have it going you can put your saved files back. Hope this helps. Let me know how you go.
Jul 23, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
Jul 15, 2009 | Western Digital My Book Essential Edition...
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
I have a Lacie Hard drive. I originally set it up on a Mac. Now when I plug it into a PC it doesn't show up, even though the computer recognizes that the hard drive is plugges in. it won't let me access...
This is normal a the hard drive is formatted for mac. If the drive is formatted using ntfs you can run Macfuse and your problem wille be solved. If not you wille need to reformat your drive in the NTFS format and then run MacFUSE.
Jan 06, 2009 | Computers & Internet
Crossfire 160gb external hard drive.
If the drive was formatted in a newer windows OS and it is the NTFS file system, the Mac OS will only have read access. You can check this by plugging it in and checking the properties. To solve this you can copy your stuff off and reformat in the FAT32 format, you will only lose the security features that NTFS offers.
Jan 29, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Maxtor Shared Storage  II (S01R320) Hard Drive Logo
88 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
