Question about JBL REM-35 Wired Remote with Display Remote Control
I have JBL MR 18 receiver with two REM 35 remotes. The display on one is not working. Any ideas? Also I see this remote is discontinued, can I replace it with a REM 45? Thank you
SOURCE: The remote with JBL Radial iPod player no longer works
Turn off the JBL at the mains, turn it back on then turn on the JBL, the remote should work it did for me.
Posted on Mar 11, 2009
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
  • 9 Answers
SOURCE: I can't find whether or not The JBL MR-17 will
It Does Not. Only standard CDs the manual is here:.http://www.prospecelectronics.com/JBL%20MR17%20manual.pdf
Posted on Jun 28, 2009
  • 3 Answers
SOURCE: lost remote
i saw one on display in edgeware road and needed the sensor at the time and i got i..t but that was years ago.. ive got the whole setup if any one is intrested?
Posted on Mar 07, 2010
tom9990
SOURCE: JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Posted on Aug 28, 2010
Jbl sb400 remote
is it the remote not working or the receiver not receiving
take your remote and point the lens at the camera of your phone
turn the camera on and when you press the remote button ( any button ) you will see a white dot on the phone screen if it is working
Jul 12, 2016 | JBL Cinema SB400 Soundbar w/ Subwoofer
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Jan 04, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
JBL MR 17
i cant get sirius to work at all, there is a new tuner but jumps back to aux wish i would of bought something else
Jul 25, 2008 | JBL - MR4W Am/Fm with CD Player White
Jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL REM-35 Wired Remote with Display Remote Control Logo
Top JBL Televison & Video Experts
Mike
mega_mind
Are you a JBL Televison and Video Expert? Answer questions, earn points and help others
