Question about Admiral AW22 Top Load Washer
My admiral super capacity washing machine
The washer seems to me its off balance but its doesnt look like it is on the spin cyclye it runs all over the place also sounds like drum is gonna pop out of the sides
    Scholar:
  • 116 Answers
Remove the front panel and check the securing springs at the bottom, probably one has snapped, replace the set.
Check for dust - evidence that the snubber washer has worn also
Posted on Jun 18, 2008
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
I just replaced the belt on my White WESTINGHOUSE la 560axw2 WASHER. It is now severely out of balance whenever it reaches the spin cycle.
The problem may be with the top springs may be damaged you can replace the spring set completely to get the smooth running in the spin
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Does not spin
    The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
    God Bless and Happy New Year.
    Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
    Admiral AW22 Top Load Washer Logo
    160 people viewed this question
    Top Admiral Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
