Question about Toshiba 36HF71 36" TV
Pink hue to picture - Toshiba 36HF71 36" TV
    Top Expert:
  • Toshiba Master
  • 74,251 Answers
Pink hue picture denotes the absence of green colour. Check the green video output transistor for open. It can be easly recogansized by taking the voltage at the collector point of that transistor. It will be high, almost equal to its supply voltage. Measure the base voltage of that transistor also. If there is no base voltage the symtom occurs. if it is so trace the track and reach to the green output pin of the related ic. If there is also no voltage, Ic may be fault. on the otherhand check the green cathode of the CRT is ok. It is quite easy. Detach all the components related to that pin, or make a temporary cut to isolate the green cathode. The switch on the set. If a green colour [High intensity] perists, the CRT is ok. You can check it in an other way. Take a 2W resistor fo value 470k or more, connect its one end to earth point, and other to the green cathode pin [Just Touch and Out], a green screen will flash on the screen. If these to checks fails, CRT is faulty.
Posted on Oct 14, 2010
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Looks like 3D tv
Try doing a calibration. Projection TVs work with 3 picture tubes (Red, Green, Blue). The Red may be off to one side causing the hues.
The manual is available here for instructions on how to perform calibration:
http://www.retrevo.com/samples/Hitachi-manuals.html#Projection%20TV
Apr 06, 2009 | Hitachi Televison & Video
The pictures come out with a pink tint when printed
go into the menu and go to color moda nad you might have it set on something else
Dec 15, 2008 | Kodak EasyShare V1003 Digital Camera
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Toshiba 36HF71 36" TV Logo
188 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
